Z6 and Y8 trannys....Same Part #'s?
Old Sep 21, 2006 | 08:23 AM
SlowPokeEg's Avatar
Mike Jones
Default Z6 and Y8 trannys....Same Part #'s?
OK, i have a 93 Si with the Z6 in it. The tranny was junk so it was swapped out for a (98 maybe?) Y8 tranny. I've heard the ONLY difference is the metal shift forks, but it's time to do the input shaft bearing on it. My question is are the part #s the same for a Z6 and Y8 tranny.
The part they gave me doesn't look like the one on Honda's drawing but the guy insists it's the right part.
I just don't wanna be stuck with the wrong part when the time comes to fix that! So please hellllllllllllllllllllllp!
Thanks!
P.S. - Do you have to know ANNNNNYTHING to work at a Honda parts dept.??? I'm no mechanic, but these guys have NO clue what parts go with what, and if you try and throw an engine code at em they freak out!!!!!!
Old Sep 21, 2006 | 07:46 PM
SlowPokeEg's Avatar
Mike Jones
Default Re: Z6 and Y8 trannys....Same Part #'s? (SlowPokeEg)
Uhhhhh anyone?
Old Sep 22, 2006 | 08:29 PM
SlowPokeEg's Avatar
Mike Jones
Default Re: Z6 and Y8 trannys....Same Part #'s? (Enzo Speed.)
Thanks. I've never cracked open a tranny before so this is slightly foreign looking to me but...
Is the ISB #9? If so, does that oil seal surround the bearings outter race? Because the seal i have surrounds the inner race. That's why i'm so confused because that drawing has me believing the seal surrounds the outter race which mine does not.
Thanks for your help, like i said, getting caught with the wrong parts would be a BAD thing when i will be taking it to a friends house to fix.
Old Sep 23, 2006 | 01:25 PM
Mista Bone's Avatar
D Tranny Guru
ISB are different, 88-95 used plastic bearing cares, 96+ used metal cages.......but I believe Honda has updated the parts so all the bearings are the new style.
ISB Bearing 91002-PS0-003
ISB Seal 91216-PL3-005
Old Sep 23, 2006 | 03:34 PM
Bense's Avatar
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">ISB are different, 88-95 used plastic bearing cares, 96+ used metal cages.......but I believe Honda has updated the parts so all the bearings are the new style.
ISBs are the same, Countershaft needle bearings are different
amej8
Jun 3, 2008 01:15 PM
97spooncivic
Feb 1, 2006 08:48 PM
H.A.R.T b16a1crx
11
Sep 11, 2004 09:01 AM
95civicSirCoupe
Jun 4, 2004 05:27 AM
egizzle8
Nov 10, 2003 12:26 PM
