steering column help eg to ek
Old Sep 15, 2006 | 10:59 AM
6shootahorsenamedtrigga's Avatar
Default steering column help eg to ek
okay i have an 95 ej1..and i got a steering column for a 96+ civic so that i can put in my s2k wheel. now i just quickly looked at it and it looks like the ignition is riveted on or hopefully its screwed on but the screw ends have a rounded end like a rivet...those that have done this swap, or anyone who has changed out an ignition switch, how the fugg do i get that ignition cylinder off? bc i dont want to have two different types of keys for 1 car and its probably going to be a bitch to get a key for that ignition anyways...do i just drill those rivet looking things out or what?
Old Sep 15, 2006 | 12:37 PM
slomofo's Avatar
GDD Member
There's anti-theft bolts on there. The head of the bolts snap off once torqued properly. To remove them, you have to get a hammer and a chisel and spin them off. You can buy replacement bolts at the dealer unless you want to chisel them back on.
Old Sep 15, 2006 | 03:04 PM
Default Re: (slomofo)
okay thanks alot!!!! could i just use regular bolts like from ace or something...just incase i have to go back to stock? and also the motion i should be concerned with is prying for the heads to break, correct
Old Sep 15, 2006 | 03:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">There's anti-theft bolts on there. The head of the bolts snap off once torqued properly. To remove them, you have to get a hammer and a chisel and spin them off. You can buy replacement bolts at the dealer unless you want to chisel them back on. </TD></TR></TABLE>
hey thanks a mil... with your info on the design i was able to get those ******* off by a stripped screw method
cast.aluminum
Dec 6, 2014 07:17 AM
tkhaab_94
Jan 24, 2010 08:19 PM
willBboostin
Mar 2, 2008 07:27 PM
B18EG6
Aug 5, 2004 12:32 PM
Boosthead
Oct 26, 2002 05:10 PM
