Converting LS/Vtec Back???
Old Sep 15, 2006 | 06:39 PM
WhiteEJCoupe's Avatar
Default Converting LS/Vtec Back???
whats good h-tech.....
got a quick ??
i was runnin a ls/vtec setup and as you know u need to change the oil pump, water pump and timing belt to a vtec setup....i ended up blowin my ls/vtec and now starting a ls turbo project....
my ?? is...would i have to convert all that crap back to a ls or can i still get away with using the vtec pumps and belt??
good looks....let me know
Old Sep 15, 2006 | 06:47 PM
qfast817's Avatar
Default Re: Converting LS/Vtec Back??? (WhiteEJCoupe)
you can use the vtec pump and timming belt if you use a vtec water pump
Old Sep 15, 2006 | 07:02 PM
Default Re: Converting LS/Vtec Back??? (qfast817)
yea i got a vtec oil pump and water pump....
it will be all good with the ls cam gears??
Old Sep 15, 2006 | 07:05 PM
another ?? too....
can i use the GSR/Type R ARP head studs in the LS??
Old Sep 15, 2006 | 07:52 PM
mec. pedri's Avatar
the 2 headstuds in the middle are gonna be too short if you use the Vtec ones
you should just get a new set of ls ones
in the future if you go vtec again then you'll already have the studs from the previous build
Old Sep 15, 2006 | 09:07 PM
Mr. LS VTEC's Avatar
My God man, why would you do such a thing
Old Sep 15, 2006 | 11:41 PM
inspyral's Avatar
All B series cam gears are the same.
jedsus
Mar 13, 2008 08:38 PM
WhiteEJCoupe
Sep 16, 2006 10:03 AM
Battle Cat
Apr 30, 2005 10:21 AM
bens_redeg
Jul 10, 2004 07:11 AM
ILOVEGIRLS
Sep 30, 2002 11:07 PM
