how many different type of clutches are there ?
Old Sep 17, 2006 | 07:52 PM
vietnamese0utlawz's Avatar
Default how many different type of clutches are there ?
hey you'll
im wandering how many different type of clutches there are since im planning to get one asap.
OEM, stage 1, stage 2 , stage 3 ,stage 4 - correct me if im wrong.
OEM is cheapest- correct me if im wrong
complete clutch kit consist of -
clutch disk, flywheel, pressure plate,alignment tool- correct me if im wrong.
and when installing a new clutch i should always replace clutch cable,new tranny fluid, and resurface flywheel and pressure plate ?
Old Sep 17, 2006 | 08:12 PM
so lazy's Avatar
Default Re: how many different type of clutches are there ? (vietnamese0utlawz)
there are 100's of clutch kits... oem isn't always the cheapest theres some clutchs on ebay that are cheap..
i would reccomend excedy haven't had any complaints on all the ones i've installed..
when installin a clutch on a cable tranny it is reccomended to get the flywheel resurface but i never do lol... i just take a air wheel with a brillo end and clean it up a bit... as for the cable line just oil the inside it should be fine... everything that comes with the clutch kit you decide on getting install it...
Fluid should always be drained out before you take the axles out it'll save you a BIG MESS.... so yeah put new honda oem fluid 3quarts you will only use like 2 and half.
clutch kit should have.. " clutch disc, pressure plate, throw out bearing, flywheel bearing, and clutch alignment tool. " also grease inner throw out bearing with like white lit.
good luck..
Old Sep 17, 2006 | 08:20 PM
Default Re: how many different type of clutches are there ? (dc2-guy)
ay bro ur hella cool haha good lookin im learning little by little
Old Sep 18, 2006 | 06:12 AM
so lazy's Avatar
no problem..
down_the_hatch
Aug 19, 2009 02:04 PM
reset2k
Apr 12, 2006 05:15 PM
JohnWayne
Jul 13, 2005 01:12 PM
civic-si-2000
12
Mar 17, 2005 05:30 PM
