losing power
Old Sep 19, 2006 | 11:05 PM
JDMtype Eg6's Avatar
Default losing power
today when i took my car for a test drive at 7.5k rpm my car jerked foward and lost power (it felt like i stepped on the brakes). i recently put in a itr header and a cat(didnt have 1 b4) i havent reseted my ecu yet but was wondering if that would help my problem. thanks
Old Sep 20, 2006 | 12:24 PM
work bump
Old Sep 20, 2006 | 12:26 PM
so lazy's Avatar
Default Re: losing power (JDMtype Eg6)
have you tried to resetting the ecu yet?? try it and come back with some info..
Old Sep 20, 2006 | 01:30 PM
slomofo's Avatar
GDD Member
If the check engine light is off, i'd check the timing belt. If it's on, check the codes and go from there.
Old Sep 21, 2006 | 05:35 PM
i heard something moving around in my brand new cat.. it looks like the back part of the internal cone as broken inside. would this be a result of me losing power due to unconstant airflow??
Old Sep 21, 2006 | 05:57 PM
so lazy's Avatar
Default Re: (JDMtype Eg6)
it looks like??? did you take your cat out or something to check this??
Old Sep 21, 2006 | 10:36 PM
Default Re: (dc2-guy)
yea i took out my piping at work and looked at it. the cone broke inside somehow(only the second half of it) but i didnt have time to take it out yet.
Old Sep 21, 2006 | 11:30 PM
so lazy's Avatar
you should try taking it out i've seen a thunderbird take a **** when the cat got stoped up somehow... if someone reads this dont ask how... cause i didn't ask the redneck dude i just seen him take it out for his mother..
Old Sep 22, 2006 | 04:51 AM
Kiniku Chunks!!!
Guest
Posts: n/a
A plugged up cat, or not functioning one, will definitely make you lose power. What type of cat did you put in??? In that case, replace it.
Old Sep 22, 2006 | 10:32 PM
Default Re: losing power (Kiniku Chunks!!!)
i had a "brand new" magnaflow cat. i took out the remaining pieces of the broken cone and now it runs fine. planning to replace it soon also.
SiR HatchAlot
Nov 20, 2003 12:18 AM
hondaciv3
Aug 26, 2003 07:16 AM
Nelo_VTI 1.5 JDM
Dec 4, 2002 02:22 PM
Isaac
Mar 1, 2002 07:05 PM
johnzm
Feb 1, 2002 04:12 PM
