STR Throttle body fix????
Old Sep 21, 2006 | 02:32 PM
hybridEj6's Avatar
Default STR Throttle body fix????
i have a 70 MM throttle body on my JDM GSR motor. This thing always sticks..around .4-.8% throttle with my foot off the gas at idle.
This in turn makes my idle stick around 1300-1900 rpm with my foot off the gas.
I cleaned the throttle butterfly with brake cleaner and lubricated the return spring.
Still sticking at idle. Anyone know a decent fix for this?? It is too expletive anoying at idle.
I have to turn the throttle cable linkage with my hand to make the rpms down.
Also I tried turning down the idle on the idle air control valve....still idles between 1300-1900
Old Sep 21, 2006 | 02:49 PM
JDM94EG28's Avatar
the same thing use to happen with my edelbrook tb
Old Sep 21, 2006 | 09:13 PM
Garage 808 Hatch's Avatar
i know 3 guys with those, including me, and they all stick
Old Sep 22, 2006 | 05:12 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Default Re: STR Throttle body fix???? (hybridEj8)
try permanently adjusting the throttle cable. If that does not work, sorry! that's all i have to offer.
good luck with that
Old Sep 22, 2006 | 07:52 AM
thesmogman's Avatar
Replace the throttle cable and do not lube it! or...
When you lube the return spring lube the shaft that goes thru the TB too.
I remove the air intake tube and with a micro oiler I lube the shaft from the inside too. This usually will last a few weeks then you have to relube it.
Or try adjusting the cable so you have a little more play at closed throttle.
My TB is just old and the H dealer wants 485.00 for it. I have been experimenting on what works, and what lasts for a while now. I know it's not an str but the workings are the same.
Old Oct 5, 2006 | 11:23 AM
hybridEj6's Avatar
Default Re: STR Throttle body fix???? (thesmogman)
ehhhh i think im fucked.....i might just put a stock one one
therealmccoy
Jun 8, 2018 09:31 AM
cdmef
Jul 3, 2011 06:03 AM
foxfai
Jul 9, 2009 07:58 AM
Mr. JDM-GSR
Aug 29, 2005 11:33 AM
eknine
Jul 10, 2003 08:36 AM
