Odometer to work with H22
Old Sep 20, 2006 | 07:26 AM
candyteggy's Avatar
Default Odometer to work with H22
ok my odometer is jumpin up and down and sumtimes stuck, i have a h22 swap on my teggy and is runnin p28 chipped.. and clusters are ITR, RPM works... but i think its like 200-300 faster... thats what i see from the VAFC.. anyone know how to make the speed meter work again?
Old Sep 20, 2006 | 08:15 AM
Down Shift Motoring's Avatar
Default Re: Odometer to work with H22 (blingbling69k69k)
sounds like a VSS prob
Old Sep 20, 2006 | 12:24 PM
so lazy's Avatar
im down with down shift there check the VSS out..
Old Sep 20, 2006 | 08:32 PM
candyteggy's Avatar
Default Re: Odometer to work with H22 (dc2-guy)
how do i check if the vss is messed up? do i need a prelude vss for mine? or the ls one well work... pics would b nice tnx
Old Sep 20, 2006 | 09:39 PM
charlee's Avatar
well u have to realize that ur odommeter runs of the speed ur going. so if u go 40 mph for a whole hour.. then ur odometer will mark 40 miles more,. pretty simple stuff. but if ur speedo is not working nor should ur odometer. if it is, ur cluster is defective.
so if ur VSS is messed up if ur needle in ur speedo is not moving.
Old Sep 21, 2006 | 12:01 AM
candyteggy's Avatar
Default Re: Odometer to work with H22 (charlee)
the tacks works... but its like 10 mph faster.. but sumtimes its stuck.. never the right speed though
Old Sep 21, 2006 | 12:21 AM
charlee's Avatar
it looks like ur cluster is messed up. the tach has nothing to do with the malfunction. this happened to me a while ago to on my prelude. i believe very strongly that ur cluster is messed up. but idk if u can get those fixed. eventho everything else might work on the cluster if the speedo doasent work ur odomoter wont work.
KevinEvo
Mar 17, 2010 07:16 PM
[713]
Mar 9, 2010 05:15 PM
watacanga
Nov 29, 2007 08:47 AM
JDMbull
Jul 20, 2006 06:30 PM
1point7db2
Dec 10, 2004 07:52 PM
