weird tachometer readings.....
Old Sep 16, 2006 | 07:38 PM
1_slow_crx's Avatar
Default weird tachometer readings.....
Im losing my mind trying to figure out with it could be. Im hoping some else has a new idea.
the problem is my tach doesnt read anything until the engine is way up in the revs. and then i know it doesnt read the engine rpm right. so basically .. its way off.
i have looked and tried my best to see if there are any bad connections and i even changed the ignitor. but there is NO difference at all. wtf could it be? the cluster?
i know what i need to do is use one of those volt meters and check my voltage at the dizzy, and before the cluster. but i dont have one!
or then doing that. does anyone have any idea what else i could check out?
Old Sep 16, 2006 | 10:13 PM
so lazy's Avatar
Default Re: weird tachometer readings..... (1_slow_crx)
just buy a new dissy and call it a day... it'll save you the time and trouble... it should fix your problem... thats what i did to my friend's 93 gsr..
Old Sep 16, 2006 | 10:47 PM
1_slow_crx's Avatar
Default Re: weird tachometer readings..... (dc2-guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2-guy &raquo;</TD></TR><TR><TD CLASS="quote">just buy a new dissy and call it a day... it'll save you the time and trouble... it should fix your problem... thats what i did to my friend's 93 gsr..</TD></TR></TABLE>
and ur friends car was running 1000% fine?
Old Sep 17, 2006 | 07:50 AM
dpaton's Avatar
Bad dizzy. No biscuit.
Rebuilt/new diizzy should fix it.
Old Sep 17, 2006 | 09:50 AM
1_slow_crx's Avatar
Default Re: weird tachometer readings..... (dpaton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpaton &raquo;</TD></TR><TR><TD CLASS="quote">Bad dizzy. No biscuit.
Rebuilt/new diizzy should fix it.</TD></TR></TABLE>
oi hope so
ef9alldatime
Sep 19, 2007 09:36 PM
hondahp21
27
Dec 22, 2006 12:18 PM
Maxime
Mar 23, 2006 08:25 PM
99CivicSiBrian
Feb 24, 2006 03:32 PM
The One Upper
Apr 22, 2004 02:08 PM
