b17 piston question
Old Sep 20, 2006 | 08:39 AM
LSVtechnologytur...'s Avatar
Default b17 piston question
When using a stock b17a1 crank/block and eagle b16 eagle rods, what pistons would you have to use to end up w/ a ~9.0 : 1 CR?
Do they need to be custom?
thanks, al
Old Sep 20, 2006 | 07:10 PM
92gisser's Avatar
Default Re: b17 piston question (LSVtechnologyturboboost)
bump
Old Sep 20, 2006 | 08:22 PM
mmuller's Avatar
Mad Scientist
you cant use b16 rods, you need b17 ones.
then youll need about a -3 cc piston
Old Sep 22, 2006 | 04:25 AM
92gisser's Avatar
Why can't you use b16 rods if custom pistons are going to be used? Thanks.
Old Sep 22, 2006 | 05:23 AM
mmuller's Avatar
Mad Scientist
Default Re: (92gisser)
then you would need pistons with a 2.13 mm higher pin height
Old Sep 22, 2006 | 06:37 AM
92gisser's Avatar
Default Re: (mmuller)
Gotcha. Thanks.
alperx
Mar 29, 2014 10:29 PM
GT500FTW
Jul 29, 2012 05:35 PM
turbotime
Mar 20, 2006 08:20 PM
Aquafina
Jan 13, 2005 07:19 PM
94tegra
Jan 26, 2004 12:16 PM
