What size pistons?
Old Sep 16, 2006 | 05:16 PM
juniestyle's Avatar
Default What size pistons?
Im rebuilding my gsr motor and im planning on doing it myself. I bought 81mm low compression pistons for my turbo setup...Im going to hone the cylinders....my question is...will the 84mm be to small to fit the cylinders...also what should the compression read on the turbo pistons if they are 9:1???
Old Sep 16, 2006 | 05:34 PM
NJIN BUILDR's Avatar
Default Re: What size pistons? (juniestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juniestyle &raquo;</TD></TR><TR><TD CLASS="quote">Im rebuilding my gsr motor and im planning on doing it myself. I bought 81mm low compression pistons for my turbo setup...Im going to hone the cylinders....my question is...will the 84mm be to small to fit the cylinders...also what should the compression read on the turbo pistons if they are 9:1???</TD></TR></TABLE>
Will the 84mm <U>what </U>be to small to fit the cylinders.
traumatrix89
Feb 24, 2011 09:02 PM
dc2_916
Sep 14, 2008 10:23 AM
legoman
Jan 25, 2005 01:49 PM
My_EP3
Apr 6, 2004 06:27 PM
crexer
May 22, 2003 09:17 PM
