Poor Man Type R?
Old Sep 15, 2006 | 07:50 PM
JDM_Frijoles's Avatar
Default Poor Man Type R?
I'm New to the scene. I have a JDM B18C (GSR) and i have my cousins old B16 Head. Exactly what do i need to do to mate the head to this block? Anyone have a write-up on this?
Old Sep 15, 2006 | 07:57 PM
swoyEKr.'s Avatar
Default Re: Poor Man Type R? (JDM_Frijoles)
just bolt it on. However, you're compression will lower by about .2, counteracting this you could use some flat bottomed valves, or most people will swap out the gsr pistons for one of four choices. Itr, ctr, p30 (jdm b16), or pr3 (usdm b16). I used the p30's for their the highest compression under the ctrs, followed by the itr, and b16, but they are lighter by far than the ctr and itr. I personally dont like the ctr because of the steep dome which will interupt airflow and possibly causing detonation at high rpm. I would reccomend the p30's as thats what i used, but i'm sure there are people that would disagree with me.
otherwise:
use gsr headstuds (11mm)
b series headgasket
you should be able to figure everything else out, if not, feel free to ask.
Old Sep 15, 2006 | 08:20 PM
Default Re: Poor Man Type R? (swoyEKr.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swoyEKr. &raquo;</TD></TR><TR><TD CLASS="quote">just bolt it on. However, you're compression will lower by about .2, counteracting this you could use some flat bottomed valves, or most people will swap out the gsr pistons for one of four choices. Itr, ctr, p30 (jdm b16), or pr3 (usdm b16). I used the p30's for their the highest compression under the ctrs, followed by the itr, and b16, but they are lighter by far than the ctr and itr. I personally dont like the ctr because of the steep dome which will interupt airflow and possibly causing detonation at high rpm. I would reccomend the p30's as thats what i used, but i'm sure there are people that would disagree with me.
otherwise:
b series headgasket
you should be able to figure everything else out, if not, feel free to ask. </TD></TR></TABLE>Thanks I think im going to go with the ITR Pistons and maybe ITR Cams.
Old Sep 15, 2006 | 11:50 PM
Mr. LS VTEC's Avatar
CTR's with ITR cams. Thats a mean combo. Thats what I had on my LS/V before I went turbo.
efking1985
May 15, 2008 08:45 PM
JDM_P.M.T.R
Aug 19, 2007 10:46 AM
blub18
Oct 4, 2006 07:51 AM
esohsee
Apr 10, 2005 04:07 PM
94delsol
Aug 23, 2004 11:41 PM
