electrical
Old Sep 16, 2006 | 07:17 AM
dopefeen's Avatar
Default electrical
hey, ok i posted on here before but no one really answered my question. i gota 94 civic hb. and seem to be having electrical problems.
1. few months ago my passenger side blinker started blinking fast even though the bulb was the right voltage.
2. then after a while when my radio would be on and i would pull on the lever for the wiper fluid there would be static in the radio.
3. my driver side back break and turn signal is very faint. and nowww when i press the break on my cluster the left turn signal arrow lights up and instead of my break light my turn signal comes on.
do does anyone have any input on this. thanks
Old Sep 16, 2006 | 09:41 AM
dopefeen's Avatar
Default Re: electrical (dopefeen)
k i konw there are some smart ppl here who can answer this...
Old Sep 16, 2006 | 10:47 AM
BuddhaSiR's Avatar
I would check the wiring. Look under the dash for bare wires or rubber insulation burnt off or wires shorted together. look at the wiring around the taillights also. Sounds like you have a short somewhere. the wiring in the brake light circuit should not have anything to do with your turn signals.
Old Sep 20, 2006 | 08:40 PM
dopefeen's Avatar
Default Re: electrical (BuddhaSiR)
ohk thanks bro...this is gonna suck going and checking everything.
Old Sep 22, 2006 | 07:17 PM
Rigginit's Avatar
Sounds to me like a possible wrong bulb installed maybe? not sure but i know having dual filament bulbs in a single filament socket or Vice Versa can throw off the speed of the flashers as well as maybe having the wrong bulb to the wrong socket. just anotehr idea to check or double chack maybe.
Old Sep 22, 2006 | 08:44 PM
dopefeen's Avatar
Default Re: electrical (Rigginit)
ya the bulbs are ok...the problem is when i press the break the driver side front and back turn signal lights up...and when i turn the turn signal on the break light blinks =\
Old Sep 26, 2006 | 11:34 PM
BuddhaSiR's Avatar
those are two seperate circuits. You most likely have those circuits shorted together.
If you want you can fly me out to Toronto and i will diagnose it for you.
Old Oct 2, 2006 | 06:59 AM
dopefeen's Avatar
no problem then u can see toronto actually no point now its starting to get cold. u should've said it while it was still summer.
Old Oct 2, 2006 | 07:24 AM
thesmogman's Avatar
This would point to a bad ground. This is the only thing common with both circuts.
Check your grounds in the tails, I should say clean them thay are probably all rusted. I would check this first.
Old Oct 3, 2006 | 12:46 PM
dopefeen's Avatar
Default Re: electrical (thesmogman)
thanks. will do.
Old Oct 14, 2006 | 02:02 PM
BuddhaSiR's Avatar
The ground is located on the right side. Description says "Right rear of cargo area"
CCrown
Jul 2, 2017 12:37 PM
Geis
Jul 12, 2015 04:26 PM
gregRULES
Feb 27, 2011 01:01 PM
Kellindal
Nov 1, 2004 05:14 PM
jimmyg
Apr 22, 2002 04:48 PM
