Eagle rods in a d16.....Block notching?
Old Sep 17, 2006 | 09:44 AM
hybrid1990crx's Avatar
Default Eagle rods in a d16.....Block notching?
So im about to start my d16a6 build and I'm wanting to use eagle rods but on there website they say:
"Please note: some minor clearancing at the base of the cylinder walls may be necessary. This is most common on older ZC, D16A, and D16Z6 blocks."
So my question is how exactly do I go about doing this? I know that I won't want any extreme edges because that will cause stress points. I'm pretty confident that I will be able to do this myself, as the only machine shop work I plan to get done is the hone.
Is there a good right up on this anywhere? I searched and couldn't find anything good that goes into detail.
Old Sep 17, 2006 | 11:54 AM
91SiZ6's Avatar
http://theoldone.com/articles/...Ftips/
Old Sep 17, 2006 | 01:39 PM
Default Re: (91SiZ6)
yeah i saw that already. i was hoping to find something to explains how to figure out how much of the block to cut out and to be more of a straight eagle rod explaination.
Old Sep 17, 2006 | 02:27 PM
TheHooded_Mike's Avatar
Default Re: (hybrid1990crx)
That article applies to any rod, including eagles. Follow that and you're golden.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slebedia &raquo;</TD></TR><TR><TD CLASS="quote">Just notch it. 1/4 inch up, 1/4 inch out, 3/4 to 1 inch wide.</TD></TR></TABLE> ^^^That's a guy on d-series.org.
Old Sep 17, 2006 | 04:19 PM
RC000E's Avatar
Default Re: (TheHooded_Mike)
The process is fairly straightforward. Put a rod on the crank with it's appropriate bearing and just work it back and forth...you'll see what it needed. In addition add at least .100 and you should have no problems
Old Sep 17, 2006 | 06:21 PM
gsrt nick's Avatar
Default Re: (RC000E)
its no big deal I use a hand held belt sander and just notch the end center of the bore. its not to technical you could do it with out any problems yourself
just mach it up and do what everybody else says get at least .100 clearence
Scott53092
Apr 16, 2014 12:27 PM
Boricuanology
Dec 25, 2006 02:05 PM
Civicdrgrcr
Nov 19, 2002 04:47 PM
93B17A
Apr 10, 2002 12:09 PM
