Urethane bar repairs
Old Sep 21, 2006 | 06:30 PM
Flip.'s Avatar
Default Urethane bumper repairs
Hey ppl,
Need some help/advice. I have a small crack(about 2.5") in my front bar(stock) and since its not visible when the lights are in the bar I'm going to try to fix it myself(needs to be fixed so the bar can be painted). I looked into plastic welding but found that it was only for hard plastics. So I was thinkin more along the lines of 'urethane putty' but I'm not sure how it works and what sort of prep work need to be done before.
Just after some general advice, hints, tips or any other alternative suggestions.
Thanks
Modified by Flip01 at 10:09 PM 9/23/2006
Old Sep 22, 2006 | 01:23 PM
Spec R's Avatar
Default Re: Urethane bar repairs (Flip01)
whats up man, most of the people here are from the US, and dont know that "BAR" means "bumper".
just a heads up before people come in here all pissed off.
Old Sep 22, 2006 | 07:22 PM
b16ej1lsd's Avatar
on the backside of the damage sand around the crack about 3" on either side with some 80 grit, then use some tape out the outside to get the shape correct and then use some fusor 142 plastic glue or equivelent on the area sanded.
once thats dry remove your tape on the outside and grind the crack down on each side and make about a 1/2" "V" shape where the crack is. put more 142 in the crack and use a spreader to even it out.
after thats dry sand it all with some 80 grit on a da and then use some flexible bondo made for bumpers to do the cosmetic work to smooth it all out. finish that off with 180 grit and then use some flexible primer on the repair area and send it off to paint if it looks good.
Old Sep 22, 2006 | 08:20 PM
HoUTX98GSR's Avatar
Default Re: Urethane bar repairs (Spec R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spec R &raquo;</TD></TR><TR><TD CLASS="quote">whats up man, most of the people here are from the US, and dont know that "BAR" means "bumper".
just a heads up before people come in here all pissed off. </TD></TR></TABLE>
heh, i was reading it like "wtf is a bar?"...
Old Sep 23, 2006 | 09:12 PM
Flip.'s Avatar
Haha, sorry about that, have edited the title now.
Thanks for you help guys, i'll have a go some time this week and let you know how I go.
Thanks again
sjbmx
Sep 1, 2009 02:09 PM
mntdewred
May 22, 2004 12:34 PM
EricUSC
May 22, 2003 12:15 PM
ActiveAero
Aug 10, 2002 07:30 PM
