b16 gears in a ls tranny??
Old Jul 5, 2009 | 07:13 AM
blackeg's Avatar
Default b16 gears in a ls tranny??
what up people! ok, now what im trying to do is make 1 good transmission out of 2 trannys. ive got a cable ls case and cable y1 b16 gears out of a trans with a cracked case. are the b16 gears a direct drop in to the ls case, seeing they are both cable actuated?
if not, what do i need to order? im also thinking of throwing an ls 5th onto the b16 1-4 on the b16 main and countershafts to help out a lil with highway driving. whats the word with it?
Old Jul 5, 2009 | 09:00 PM
stevenDAtegra's Avatar
Default Re: b16 gears in a ls tranny??
Yes you can. I did it with mine. It won't work if the ls tranny is a 92-93 tranny though because the splines for the clutch on the mainshaft are different
Old Jul 6, 2009 | 10:45 AM
blackeg's Avatar
is the splines the only difference? both of the trannys have the same splines on the mainshaft
Old Jul 9, 2009 | 06:20 PM
blackeg's Avatar
uppity, would like to bolt this together soon
Old Jul 10, 2009 | 05:43 PM
Wopsicle69's Avatar
like stated, if the cable ls trans is from a 92-93 integra, then NO the b16 gearset will not work, but if the cable ls trans is from a 90-91 integra then YES it will work. The 90-91 integra trans and the jdm b16 trannys have the same small spline input shaft. The 92-93 integra gearsets have the same big spline input shaft as all other b series hydraulic trannys. If you look at both your trannys and see the same spline input shaft then you should be good to go.
Old Jul 11, 2009 | 06:38 AM
blackeg's Avatar
ok, both of the transmissions have the same spline count, the 92-93(+) spline count. should be good to go im gonna put this together today
gen2_4door
Feb 4, 2011 08:51 AM
punxsk8r555
Transmission & Drivetrain
Nov 29, 2010 04:07 PM
Junkyard
May 14, 2009 09:22 PM
