Installing valves
Old Jun 27, 2009 | 04:21 PM
kornerk12's Avatar
Default Installing valves
When installing new valves into a cylinder head is it necessary to use a lapping compound and spin the valves for a few moments to help them seat or are they ok out of the box ? Is the angle of the valve job always the same as the valve ? What about on radius valve jobs ?
Old Jun 28, 2009 | 06:29 AM
kornerk12's Avatar
Default Re: Installing valves
bump
Old Jun 28, 2009 | 03:55 PM
delsol904's Avatar
need to know too
Old Jun 28, 2009 | 04:18 PM
1992Si's Avatar
If this is a street engine I think you better call a local machine shop in your area.
I installed new valves in our race head right out of the box, but they were drop shipped to us from Manley per Brad at RLZ.
Old Jun 28, 2009 | 06:18 PM
riceburner700's Avatar
has the valve seat been cut?
Old Jun 28, 2009 | 06:48 PM
kornerk12's Avatar
But wouldnt the correct way be the correct way, regardless? What was different on your race motor than a street motor that would affect this aspect ?
Old Jun 28, 2009 | 06:49 PM
kornerk12's Avatar
No but could I hear what you have to say in both cases.
Old Jun 28, 2009 | 07:04 PM
if not then yes i would lap them in the best you can or spend the money and have the valve seat cut so you know you have a %100 seal
Old Jun 28, 2009 | 08:43 PM
kornerk12's Avatar
so technically with the valve job then valve should not have to be lapped ? Will the angles on the valve always match the valve seat ? For example sometimes they use 3-5 angle or even radius valve job, wouldn't that affect the seal ?
rotascircuit
Jan 7, 2010 12:52 PM
kornerk12
11
Jul 3, 2009 03:55 AM
beyondstock
May 23, 2009 05:43 PM
importboi22
34
Feb 8, 2007 12:43 AM
Aeka GSR
Oct 7, 2003 06:18 PM
