oil pressure
Old Jul 9, 2009 | 03:58 PM
dragvixen's Avatar
Default oil pressure
noob question im sure. i just started my new build up and i have got like 78 psi of oil pressure, now me never have had a guage to know but does this seem like a lot to anyone else. Thx in advance
Old Jul 9, 2009 | 03:59 PM
dragvixen's Avatar
Default Re: oil pressure
thats the pressure at idle, if wondering
Old Jul 9, 2009 | 04:08 PM
Psychoteen101's Avatar
Thats typically a pretty good number. What motor do you have?
Old Jul 9, 2009 | 08:18 PM
srmofo's Avatar
^ are you high??? Although the engine isnt listed, thats way high...typically speaking at idle should be around 25psi min.....3000rpms should be around 50psi min although things can vary a little depending on ambient temp, oil viscosity, and clearences.
Old Jul 9, 2009 | 11:32 PM
lol, ive had about 5 different motors in my car, all were right around the 80psi mark at idle. Those were all bone stock, with more than 80,000 miles on them.
Old Jul 10, 2009 | 05:37 AM
srmofo's Avatar
well its no wonder you have had 5 different engines in your car with oil pressure that high.....or your guage is just way off.....this is taken directly from mitchell ondemand
oil pressure at idle should be at 10psi (0.7kg/cm2) minimum. Oil pressure at 3000 RPM should be 50 psi minimum (3.5kg/cm2) minimum.
also since I do not know which engine he has, I just picked a '95 b18b, but most honda engines are around the same specs
Old Jul 10, 2009 | 07:28 AM
dragvixen's Avatar
i figured it out my guage was wrong,i got
b18a1,
81.5mm,
8.9:1 pistons,
eagle rods,
stock rebuilt head,
skunk2 cam gears,
t3/t4
greddy BOV.
once i got all the air out of the line it read right, thx guys i thought that was way high
Old Jul 10, 2009 | 10:57 AM
srmofo's Avatar
what is it currently at?
Old Jul 10, 2009 | 11:20 AM
dragvixen's Avatar
about 32-35 it idle and 45 psi at 4500 RPM? sound right
Scoberdoo
Nov 12, 2018 07:55 AM
trulyshavedintegra
Dec 9, 2012 05:06 AM
ProjectBB6
Sep 16, 2009 02:18 PM
platinum00
May 14, 2006 06:40 AM
fanta!
Aug 11, 2005 02:34 PM
