Rev limiting at 2500
Old Jul 7, 2009 | 01:00 PM
96B16civic's Avatar
New User
Default Rev limiting at 2500
I'm having a problem with my engine rev limiting at 2500RPM. Its a B16 OBDII to OBDI conversion and I just did a turbo engine build on it. When I rev it up it will hit 2500RPM and drop down to about 1200 and then rev back up and do the same thing. On my hondata I'm throwing the Codes for IAC, Knock sensor and Vtec spool error. I'm also hearing some engine knock pretty seriously. Some locals say it might be a bent valve, wrist pin problem, or a warped crank. any ideas on this issue would be great! thanks in advance for the advice!!
Old Jul 7, 2009 | 01:06 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: Rev limiting at 2500
wow. fix those CELs first and then try a stock ecu. your hondata can hav limiter preset to 25oo right now.
brcorp
Jun 29, 2009 09:00 AM
ren1
Nov 2, 2008 09:27 PM
KillaB18
Jan 14, 2004 07:22 PM
nautica_t
27
Oct 29, 2002 03:39 PM
