car won't start need help
Old Jul 6, 2009 | 10:39 AM
boostfever's Avatar
Default car won't start need help
my car was sitting outside for 3 days with the gas at empty. went to the gas station and got 1 gallon and pour it now won't start. (didn't drive the car to the gas station) just bought a new battery a month ago. i can hear the fuel pump humming and check the fuel filter and fuel there was fuel. anyone know what might be wrong??
Old Jul 6, 2009 | 11:17 AM
fcm's Avatar
fcm
Old Fart
Default Re: car won't start need help
MM&Y of car ?
You say you can hear the fuel pump prime the fuel system when ign. switch is turned on, is that correct?
Does the engine turn over, [crank] and just not fire up, [start], or does the engine not even turn over?
Have you pulled a spark plug to see/smell if there is gas on it?
Have you checked to see if you have spark? 94
Old Jul 6, 2009 | 08:26 PM
boostfever's Avatar
99 honda civic. I got car to turn over today for 5 minutes then dies. Just put in some new spark plugs in today also.
Old Jul 7, 2009 | 03:39 PM
boostfever's Avatar
need some help asap cause i need to take my car to get it tune.
Old Jul 8, 2009 | 11:14 AM
fcm's Avatar
fcm
Old Fart
You said, "I got car to turn over today for 5 minutes then dies", do you mean you had the engine running for 5 min., or just cranking to start, [turning over]?
I asked...
"Have you pulled a spark plug to see/smell if there is gas on it?
Have you checked to see if you have spark?" 94
Old Jul 8, 2009 | 02:51 PM
boostfever's Avatar
yes the engine actually started for about 5 minutes until i tried to rev it up to about 3k rpm. now i can't turn the car on anymore and evertime i try to turn the car on all of the lights fades away everytime i try to start the engine.
i took the old spark plugs out and it head some oil on it so i changed it with some new ones. i don't remember smelling gas on the spark plugs.
Old Jul 8, 2009 | 04:11 PM
fcm's Avatar
fcm
Old Fart
You have a power or ground connection problem...
"all of the lights fades away everytime i try to start the engine."
or a low batt. 94
ninjaturtleEG
Sep 14, 2016 11:15 AM
1sikhatch
Honda Civic (2001 - 2005)
24
Mar 21, 2010 02:49 PM
z crx z vtec z
Jun 13, 2007 03:19 PM
BlueLude84
Jan 13, 2007 10:11 PM
lilsaigon510
Mar 29, 2005 12:10 AM
