clutch fork stuck. help.
Old Jun 30, 2009 | 10:29 AM
topp_dawg_g's Avatar
From: springdale, arkansas, United States of America
Default clutch fork stuck. help.
after finishing my swap (prelude h22) my clutch fork and the clutch slave cylinder is just stuck. i can't move it manually from outside. i notice when i tried bleeding it. the fluid goes down only a little, almost not noticeable. i move from a thicker pressure plate to the stock one, if that matters. could it be the bearing out of line or do i just need to adjust the pedal?
Old Jun 30, 2009 | 11:06 PM
delsolproblems's Avatar
Default Re: clutch fork stuck. help.
You really shouldn't be able to move the fork by hand with a new stronger plate. You probably want to check the hydraulic system some more.
Old Jun 30, 2009 | 11:47 PM
1992Si's Avatar
That's why you step on the clutch pedal with your foot.
If I could depress the PP by hand, I'd be worried.
cockeyedcricket
Sep 25, 2009 12:48 PM
[713]
Jun 20, 2009 08:23 PM
Nextelbuddy
12
Jul 14, 2003 11:34 PM
SpoonFed
Apr 10, 2002 05:33 PM
