having a little issue here
Old Jul 12, 2009 | 01:07 PM
vaspeeder's Avatar
Default having a little issue
problem solved
Old Jul 12, 2009 | 02:16 PM
KWayRacing's Avatar
Default Re: having a little issue here
Check the wire connections inside the distributor. Oh does the car run fine when the tach is dancing? If so check those connections and also make sure the blue wire at the distributor plug hasn't been taped into. skinned.
Old Jul 13, 2009 | 08:07 PM
KWayRacing's Avatar
It is very possible.
Old Jul 14, 2009 | 02:01 PM
philafelman's Avatar
everytime ive seen the tach jumping around like its possessed, the cluster (tach) is usually bad.
Old Jul 15, 2009 | 11:17 AM
92_civic's Avatar
I was going to say, every time I see the tach jumping like that it is the ignitor or icm in the distributor...
Old Jul 16, 2009 | 07:44 AM
EJ1B18c's Avatar
i once saw this problem it turned out to be the earth wire that goes onto the thermostat housing was loose.
Old Jul 16, 2009 | 08:05 AM
kyden's Avatar
Originally Posted by vaspeeder
thanks, turns out it was the dizzy swapped with another dizzy it ran find....dizzy i had was brand new but anything can be defected even if its new..time go back trade for new one
aftermarket distributors are junk!
1234567899876543211230
Aug 15, 2006 11:52 AM
De_tour
Dec 15, 2005 06:59 PM
fatboyslim44
May 5, 2004 07:56 PM
its WANG yoO
Dec 9, 2003 09:19 AM
B20zvtecek
Jun 24, 2002 06:47 AM
