How to set your idle?
Old Jul 1, 2009 | 09:58 AM
djnikko's Avatar
Default How to set your idle?
Ive just finished a H22 EG swap and after sorting out a few wiring bugs im wondering what the correct procedure is for setting up the idle. Unfortunately ive already moved the idle screw which I probably wasnt meant to. Can anyone tell me how the idle screw should roughly be set? and also should the car start and run with the accell cable slackened off? Or should it pull the butterfly open slightly?
I was thinking should I idle the car high untill warm, then adjust it down to 750rpm or nearest I can get to it then disconnect battery to reset ECU and start again for 10mins without pressing the gas? Of course only once I have sorted the relationship between the idle screw and accell cable.
Thanks in advance
mitchh29
10
Mar 6, 2013 08:18 PM
slowassBubble
11
Mar 17, 2011 06:37 PM
b18c4door
15
Nov 26, 2007 08:22 AM
94typeR
Mar 28, 2007 05:49 AM
daddymaxx
Dec 15, 2003 12:24 PM
