a/c install on integra
Old Jul 9, 2009 | 10:15 AM
ivan93egreppin210's Avatar
Default a/c install on integra
can anyone point me to a good diy on how to install a/c backin my car. everything up to the fire wall was removed. my helms has pics but doesnt go into detail on how to reinstall it. (see section 22-3 to 22-6 ) for best pics of complete setup in helms.. i will make us a detailed write up for our FAQ upon installing my system. thanks.
posted this in the integra forum 3 days ago . 75 views and no replys.
Old Jul 10, 2009 | 06:17 AM
fcm's Avatar
fcm
Old Fart
Default Re: a/c install on integra
I know of no good write ups on DIY A/C "reinstall", but if you have all the parts, [condensor, compressor, filter/dryer, hose assemblies, hoses/piping and switches, it should be straight forward, it will all only fit together one way, you will have to put proper amount of refrigerant oil, [Ester oil] into the system, I would replace the filter/dryer and all "O" rings.
What year is the Teg? 94
Old Jul 10, 2009 | 02:06 PM
sure is bro. thanks for the reply.
a guy offed me an 98 LS compresor for a 100 bucks. are all LS cmpresors the same? also can i use my old lines with R134? can i buy 95 and up lines? will it line up the same or should i just convert the R12 lines to R134 with an adapter kit?
Old Jul 10, 2009 | 03:49 PM
fcm's Avatar
fcm
Old Fart
I will assume it is a 93LS and I will check if it is the same compressor, unlikely as yous is an R12 system, you can retrofit your R12 system to the R134a system by replacing the filter/dryer cycling switch and adding the R134a service ports and charging the system with R134a.
If the compressors are the same, [93 - 98] you can switch the compressor and use the original lines, even if it is a diff. compressor but it has the same manifold and pulley then you will be able to swap to the compressor but still use your old lines.
I will have to check that at the shop tomorrow.94
Old Jul 10, 2009 | 04:52 PM
KWayRacing's Avatar
Wait 94 teg is R134a system isn't it ?
Old Jul 10, 2009 | 08:19 PM
my car is a 94dc. im going to get that compresor in the morning. i have a 00 b20z2 in my integra. it had the a/c bracket. this is the same as an LS right?
Old Jul 11, 2009 | 10:47 AM
fcm's Avatar
fcm
Old Fart
OIC, a 94, re; "sure is bro." to my, "What year is the Teg? 94"
94 is the way I end all my posts.
Not sure, but it is unlikely that the stock 94LS compressor, [and mounting brackets] are the same as the b20z2, although MM&Y of car will determine compressor used, engine model/size is also a determining factor, you will need the compressor from a b20z2, [most likely]
The 94LS, [and the 00b20z2] both use R134a systems.
What was the MM&Y of car the b20z2 came out of? 94
Old Jul 12, 2009 | 08:29 AM
fcm's Avatar
fcm
Old Fart
OK, so far I have found all Integras use the same compressor, the 92 also had a "type 2" compressor, it is not specified what the diff. is.
I can not find a Honda or other Acura that uses the same compressor. 94
Old Jul 19, 2009 | 10:29 AM
i just finished installing the entire system. i cant find specs for how much oil to add or how to add it.
Old Jul 19, 2009 | 04:12 PM
fcm's Avatar
fcm
Old Fart
I will let you know tommorow.
What is the b20z2 out of? 94
Old Jul 19, 2009 | 04:23 PM
im using an LS compresser and bracket mounted to my b20 block.
Old Jul 20, 2009 | 06:37 AM
fcm's Avatar
fcm
Old Fart
24oz R134a and 5oz PAG-46 or Ester oil. 94
Old Jul 20, 2009 | 04:38 PM
still kinda stumped as far as how to add the oil. it appears that its installed the same as the r134. is this correct? so does the 24 oz from the r134 and the 5oz from the oil mean my system can only hold 29oz's worth of the mixture?
the answer to my own question is NO its not. LS compressor is not the same as b20.
in order to use the LS compressor i had to have the LS bracket. it bolted up to the b20 block.
now on the other hand if you owned a civic and just swapped an LS in, you would need the b20 bracket. the civics and cr-v's use the same compressor.
Old Jul 20, 2009 | 05:06 PM
fcm's Avatar
fcm
Old Fart
Yes a total of 29oz, we would put 2oz in the filter/dryer and the other 3oz in the compressor, but because everything is already in you can have the shop that does the recharge inject the 5oz of oil while recharging, or you can disconnect the suction line to the compressor and pour it down the suction line into the compressor, compressor needs to be turned 10-20 times, [clockwise] once oil is put in.
A good idea is also to put in 2oz of C4 oil into the compressor, we do with any used or re-man compressors. 94
Old Jul 15, 2010 | 05:15 PM
BETO_20DA's Avatar
I have a very bigg similar problem..I got a 91 integra with a b20b motor, which has a compressor on there which is frozen according to the ac technician( he says the clutch is stuck or wont turn so I need new one)..What other car should I get it from? Are all B Series compressor the same? Should I just get a remanufactured compressor? If I buy use how can I check if its good or test? Any info guys?
Old Jul 24, 2010 | 07:37 PM
BETO_20DA's Avatar
So if you have a b20 you can use the same lines and everything? But you must convert fittings and all to r134, Correct? I have a b20b it has a compressor, but not sure if I have to put LS OR B20b compressor?
thugsbryan
Mar 11, 2019 03:04 AM
ivan93egreppin210
Jul 8, 2009 08:56 PM
vestalfootball72
Dec 7, 2007 06:46 AM
HCJDM1
Feb 9, 2007 04:28 PM
rambler
56
Oct 30, 2002 12:53 PM
