LS & B20 part swaping ?????
Old Jul 2, 2009 | 11:25 AM
bluenc-87's Avatar
Default LS & B20 part swaping ?????
Okay, I have a b20 block. I want to know if the following parts will fit my B20 block:
ls oil pickup tube
Ls oil pan
gsr coolant pipe (behind block) to my b20 block
Old Jul 3, 2009 | 10:25 AM
vanny_david's Avatar
Default Re: LS & B20 part swaping ?????
which LS block ?
B18A or B18B?
I am also doing the same thing from B18A to B20B4
but I found out the rear main cover are different
I am still finding out whether the oil pan fit or not...
Old Jul 3, 2009 | 11:39 AM
Ruben19's Avatar
ls oil pickup tube
Ls oil pan
everything fit but the coolant pipe might have some extra outlets.
Old Jul 5, 2009 | 11:28 PM
V8 Eater's Avatar
here is some info for you that youll be gratefull for later on my friend.
I hit my oil pan in an accident on my b20z and swaped my oil pan from the 95 ls I had. this caused the oil to build up higher then normal,how you say??
well apparently the b20 oil pan is slightly different and has a taller wall for the extra oil the b20 requires over the ls, the ls oil pan being a little short will not be able to hold that amount of oil specified for the b20. this is what messed up my oil pressure and fcuked up my seals. it also causes the oil stick to miss read. It was reading max when really it was still in need of half a pint
94EGCoopey
May 12, 2014 12:52 PM
truongmai8d
Aug 19, 2010 03:07 PM
HondaBoy954
Dec 8, 2008 11:19 AM
T9U4ReBgO
Nov 17, 2007 10:56 PM
Andre
Nov 25, 2003 04:35 PM
