d16 to b16. big project??
Old Jul 2, 2009 | 04:32 PM
wolf95's Avatar
Default d16 to b16. big project??
ok, so I am going to be putting money aside for a b16a1 swap to put in my 95 del sol si. I looked online and on ebay i can find one for around $1800 and on tigerjapanese for about $1900 with tranny and ecu.
I know i will also need:
shift linkage
cv axles
radiator
mounts
how HARD ( say hard even though thats a broad word) would it be to do this swap? I will be around ppl that have done swaps and i know they will help me but I would like to be as prepared to tackle this as much as i can be. any tips? any suggestions? sites? any more info would be very helpful. thank you
I'm not sure where exactly this would go but this seemed like a fine spot.
Old Jul 2, 2009 | 06:02 PM
KWayRacing's Avatar
Default Re: d16 to b16. big project??
This is a very straight forward swap. You can make it very easy. Under 6 hours with preparation even for beginners. I can't stress the prep work enough? It can be done with research and planning. Go ahead remove and label if wanted/ necessary the harness off the JDM motor. Freshent the motor up(Complete T Belt service/ tune up at least) ahead of install day. Get 94 Del SOl VTEC heater and radiator hoses.WHich means very few parts will actually be installed swap day. Buying fluids ahead of time Oil/trans/coolant. HAving parts/answers to questions like how do I keep AC/ps before swap day. Now with mounts/ linkage/ axels its just as easy as swapping the original driveline. Thats the long way to say easy. I have done this almost exact swap(EGSi instead) from start to finish in less than 3 hours.
Old Jul 2, 2009 | 11:42 PM
wolf95's Avatar
wow thanks. good advice. any more would be even more helpful. and good sites to find those parts
Old Jul 14, 2009 | 03:14 PM
91rexy's Avatar
if you go to http://www.jdmsource.ca you can get a b16a1 for about 1500 plus shipping and it comes with:
Engine
Transmission
ECU
Alternator
Air Conditioning
Power Steering Pump
Distributor
Intake and Exhaust manifolds
Down Pipe
Starter
heres the link: http://www.jdmsource.ca/v2/product.asp?ID=65
Old Jul 14, 2009 | 03:49 PM
91rexy's Avatar
But your car should have a hydraulic tranny and in that case you would want to get the b16a2 which you can find on the same site i said earlier and is around 2000
Old Jul 14, 2009 | 03:55 PM
philafelman's Avatar
you might want to research that tigerjapanese place....im not 100%, but i thought ive read negative things about them on here. u should research any place you buy the engine from though, just in case.
https://honda-tech.com/forums/showth...=tigerjapanese
Old Jul 14, 2009 | 04:04 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Old Jul 14, 2009 | 04:05 PM
Vietnamese!
www.hmotorsonline.com is the way to go.
Old Jul 14, 2009 | 06:01 PM
Blown90hatcH's Avatar
werd. Any make sure you are getting the OBD1/2 setup with hydro tranny, ecu, etc.
Or save up a little more and get the GSR.
Old Jul 15, 2009 | 01:37 PM
91rexy's Avatar
no jdmsource.ca is the way to go. they will give you all the information you need. there engines are around 20,000 miles. hmotor offers at around 3500 and they dont give you very accurate compression test readings
DOHCturbo
Feb 15, 2012 07:14 PM
guachi1209
10
Jan 17, 2012 01:09 PM
maka
20
Mar 11, 2005 08:51 PM
gSx.
Apr 7, 2004 09:29 AM
