CRX H2B alternator problem
Old Jul 9, 2009 | 09:30 PM
NewEra's Avatar
Icon6 CRX H2B alternator problem
I have a H2b on my CRX using a D series alternator. The battery light on my cluster stays on and have no idea if the battery is charging, but when i rev pass 3000rmp the light turns off and at idle turns back on. any help would be nice thanks
What is needed to use a D series alternator on a H22A? Do i need to change to higher amp fuse for alternator, i have no idea what the problem is. checked wiring twice and its good
Old Jul 9, 2009 | 10:10 PM
SIXTY's Avatar
Default Re: CRX H2B alternator problem
The alternator could be going bad, what alt bracket are you using? I used a d-series alt on my H2B crx with no problems, i used the esp bracket.
Old Jul 9, 2009 | 10:30 PM
NewEra's Avatar
im using the stock h22 bracket for now bolting the top bolt only. i replaced the alternator with a good working one same problem forgot to metion that.
thanks for the quick reply
Old Jul 15, 2009 | 09:14 PM
Gen2ITR's Avatar
Battery, ELD, wiring, or the alt itself... What crank pulley are you running?
Old Jul 19, 2009 | 09:33 PM
NewEra's Avatar
fixed my problem put on the h22 alternator no more light thanks guys.
Old Aug 4, 2009 | 06:51 PM
luiscvc's Avatar
hi guys,
i'm in the process of finishing my h2b in a 90 sedan. could you say what you did to solve your problem so other people dont encounter it too??
thanks.
EJ8_Man
May 25, 2019 10:21 PM
bindolus
Nov 4, 2015 07:05 PM
CRX831
Jul 6, 2009 02:01 PM
19da90
Jul 8, 2004 11:36 AM
