Idle fluctuations
Old Jul 1, 2009 | 10:41 PM
muffler man's Avatar
Default Idle fluctuations
Motor: 94' B18C1
Problem: I turn on the car first thing in the morning and its idling around 2000rpm sometimes a little higher. when it reaches operating temparature it idles up to 2000 rpm then it drops down to 950-1000rpm and back up to 2000rpm constantly. annoying as hell and I would like to fix it.
Trouble shooting: I checked the ecu and it threw code 14. I replaced the IAC valve and reset the ecu and no more code, but the idle is still the same. Due to a tight work schedual I haven't had time to look at everything. I am assuming it might be vacuum lines, or the PCV valve but I would like to know what other issues will cause the idling problems. TIA.
Old Jul 1, 2009 | 11:02 PM
Ruben19's Avatar
Default Re: Idle fluctuations
clean the IAC valve and check for vacuum leaks. also try adjusting the idle screw.
Old Jul 2, 2009 | 12:49 PM
I replaced the IAC valve with a brand new one, I am in the process in looking for vacuum leaks. But just for a list of possibilities, what are some causes for idling problems?
Old Jul 2, 2009 | 01:12 PM
Ruben19's Avatar
map sensor, cracked intake manifold, poor tuning(ecu)
Old Jul 2, 2009 | 01:40 PM
Thanks for the input. I bought the car with the motor swapped in it from my cousin, no tuning was done to the ecu. A bad PCV valve will cause bad idling correct?
Old Jul 2, 2009 | 02:06 PM
Ruben19's Avatar
yes, try the pcv valve
Old Jul 2, 2009 | 02:27 PM
jdm inc's Avatar
check your tps sensor also.
Old Jul 2, 2009 | 09:45 PM
I checked the PCV valve, I notice one of the hoses was split so I replaced it. I also shook the PCV and it rattled, so its still in good condition. Idling problem still exist.. would a bad/faulty TPS throw a CEL code? I so, I have not codes being thrown. What should be a next step to trouble shoot my idling problem?
Old Jul 2, 2009 | 10:32 PM
Ruben19's Avatar
try another car ecu
Old Jul 5, 2009 | 09:57 AM
does anyone know what internal problems will lead to idle fluctuations? camshaft, cam gears, etc. ?
Old Jul 6, 2009 | 12:44 PM
Mikey3000's Avatar
https://honda-tech.com/forums/honda-prelude-4/end-all-idle-surge-bounce-etc-problems-thread-1979500/
Old Jul 6, 2009 | 12:53 PM
dlaub25's Avatar
Don't the 94s still have the FITV under the throttle body? That would be the first thing I check.
Old Jul 6, 2009 | 02:01 PM
When the idle was bouncing around, I covered the lower hole inside the throttle body, and it still bounced around. Then I covered the upper hole and the bouncing stopped and idled at 1500 rpm.. any input?
Old Jul 7, 2009 | 06:09 PM
BUMP. Also, would the MAP sensor be a source of the problem here?
Old Jul 8, 2009 | 08:12 PM
BUMP
Old Jul 14, 2009 | 02:27 PM
I replaced the FIT Valve, and the problem still exist. Can anyone on HT give me any pointers?
integra15
Jun 23, 2010 02:30 PM
JBirch_97Prelude
Mar 26, 2007 08:43 AM
Vp Special K
Nov 9, 2003 03:06 PM
Rain_man
Apr 8, 2003 08:45 AM
ITR41
Dec 16, 2001 04:15 PM
