reusing arp head studs
Old Jun 27, 2009 | 04:19 PM
kornerk12's Avatar
Default reusing arp head studs
Is it ok to reuse the stud and nut after they were used for around 10k ? Is there a stretch limit ? What actually causes the bolts to stretch ? Is it re-torqeing the bolt that cause stretch or just the amount of pressure on it constantly while running ? How would you measure this ?
Old Jun 27, 2009 | 06:19 PM
Turbo B18C EJ6's Avatar
Default Re: reusing arp head studs
Yes you can reuse them. Friends of mine have reused them at 2 or 3 times, after 3 times I would then change them, but your good to reuse them over again. I think arp makes a thread gauge for mesureing bolt stretch.
Old Jun 27, 2009 | 09:44 PM
kornerk12's Avatar
they do but u need access to the other side of the bolt to do that and that gauge is specifically for rod bolts, i think a head stud would be wayyy too long.
Old Jun 28, 2009 | 06:29 AM
kornerk12's Avatar
bump
Old Jun 28, 2009 | 06:55 AM
The Flash's Avatar
i have reused them before on my supra if that helps
aluminum head steel block
eddie7978
Engine Machining & Assembly
25
Feb 22, 2018 08:19 AM
bow tie
Oct 21, 2008 12:03 PM
b20vtech
Feb 23, 2006 07:45 PM
ELSpool
Jul 28, 2003 11:21 AM
B18EG6
Mar 24, 2003 07:41 AM
