Rekey a door lock?
Old Jun 24, 2009 | 11:04 PM
MDRGuy88's Avatar
Default Rekey a door lock?
i own a 91 integra RS, i recently replaced the ignition and would like to just use 1 key, should i buy a kit and try and do the door locks myself (im very mechanical) or just say forget it and use 2 keys
Old Jun 25, 2009 | 04:50 AM
standbackimapro's Avatar
Default Re: Rekey a door lock?
Well its really a Choice you would have to make, Do you not mind using 2 keys?, do you really want to go out and buy new door lock cylinders when theres nothing wrong with them?
Old Jun 25, 2009 | 07:36 PM
MDRGuy88's Avatar
well i dont have the original keys, the prior owners lost them, i would have to replace the locks, what would be cheaper?
Old Jun 26, 2009 | 04:56 AM
Furyof4's Avatar
You can modify the door lock to accept the ignition key. Remove the lock cylinder from the door, insert the key you want to use, and then file all the brass slides down to the body of the cylinder. Just did this on my hatch. Takes some time but works.
Old Jun 26, 2009 | 01:19 PM
pgpbubble's Avatar
Its easiest to take your door locks out and bring your ignition key and or cylinder to the dealer and have them do it.
At least its not a sidewinder...
Old Jun 26, 2009 | 09:51 PM
MDRGuy88's Avatar
how much would a dealer charge me, if its to much ill do it myself
Old Jun 27, 2009 | 02:59 AM
delsolproblems's Avatar
A locksmith should be alot cheaper than a dealer.
Old Mar 18, 2016 | 11:11 PM
grayzz's Avatar
anyone with a diy? have the same problem
spooncivic1
Dec 15, 2021 09:11 PM
Valvos
17
Jan 18, 2013 08:00 PM
cfrederiksen
Honda CR-V & Element
Dec 5, 2012 04:07 AM
renegadez7o7
Jun 6, 2006 04:55 PM
projectPSI
Feb 23, 2005 05:04 PM
