my h22 build
Old Jun 25, 2009 | 08:56 PM
h22hatch88's Avatar
Default my h22 build
so i have obtained an h22a4 for about 45$(super deal! ), and so far everything is disassembled , the block looks really good, just some burrs where one of the thrust washers go, so the block is bare now, and next week or so i am sending it to get hot tanked, cleaned and resurfaced. and also the head to get hot tanked and cleaned and resurfaced with a 3 angle valve job. My question is: what do i need to leave in the head(or remove) when i take it to the shop. mind you i am getting a whole new valve train, but right now just the stock valve train is in it. and also does anything need to be in the block. any help is greatly appreciated. thanks
Old Jun 27, 2009 | 10:22 AM
all4imports's Avatar
Post Re: my h22 build
Ok I just went through all of this with my f20c1, and if you are doing the work yourself, take everything apart. I would just send the bare block and the bare head. Also depending on how long the engine sat for, I would also consider removing the freeze plugs. You would then gaurantee that you would end up with a completely clean engine inside and out. If you are sending the engine to someone to do the build for you, I would suggest to leave the engine as a longblock minus the the manifolds of course. Everywhere I went told me they will only return the engine in the condition in which they recieved it. Dont know if this will help or not but hopefully it does. - Ryan
Old Jun 28, 2009 | 04:41 PM
h22hatch88's Avatar
Default Re: my h22 build
ok thanks, well im doing the build, and i just didnt know if the head needed to be assembled to do a valve job. the block is 100% bare nowjust the sensors. what is a freeze plug?
Old Jun 29, 2009 | 08:44 AM
h22hatch88's Avatar
bump
hoffdaddy
Engine Machining & Assembly
Jul 27, 2015 01:02 AM
Mr_Si-R
Oct 12, 2005 01:53 PM
cubanSiR
May 5, 2005 04:15 PM
93NXLUDE
Nov 12, 2003 06:09 PM
-16V-
Oct 17, 2002 09:29 AM
