ACT Clutch
Old Apr 1, 2002 | 06:31 PM
LostGsr's Avatar
Default ACT Clutch
I'm planning to install the Act modified street clutch on Wednesday. Does anyone have any experince on this clutch? Is the pedal pressure about the same as stock?
Old Apr 1, 2002 | 06:33 PM
EP3_05's Avatar
Default Re: ACT Clutch (LostGsr)
I was using an ACT HDSS clutch on my ZC swap. The pedal pressure was much higher than stock. I was using a heavy duty pressure plate. It wasn't that tough once I got used to it. It was a very nice clutch by the way.
Old Apr 1, 2002 | 09:03 PM
IN VTEC's Avatar
HD-SS too on my GS-R with 9lb FW.
The pedal pressure is definitely bearable. It is a little annoying on hills and in stop-n-go traffic or both at the same time.
Old Apr 1, 2002 | 10:31 PM
image-evo1's Avatar
New User
im using an ACT clutch on my B16 and i have no problems running it with the JUN UL flywheel. pedal pressure is a little higher, buts it's a lot nicer feel than stock
Old Apr 1, 2002 | 11:38 PM
Newbie In A Teg's Avatar
Default Re: ACT Clutch (image-evo1)
Anyone know the difference in pressure between the heavy duty + street organic setup and the xtreme + street organic? anyone actually using the xtss setup? hook up some info please
Old Apr 2, 2002 | 01:51 AM
TypeSH's Avatar
Default Re: ACT Clutch (Newbie In A Teg)
For you guys w/ the ACT heavy duty clutch kit for a civic/integra... have you guys driven a stock prelude or accord clutch? To me, the stock accord/prelude clutch requires much more pedal pressure than the civic/integra one.
Can anyone compare the integra/civic ACT heavy duty clutch to the stock accord/prelude clutch?
Old Apr 2, 2002 | 07:09 AM
John's Avatar
New User
Default Re: ACT Clutch (TypeSH)
I have the XTPP w/ SS disc in my Accord, and the pedal pressure is extremely high... My friend has a HDSS in his 'Lude, and his was much more comfortable. Note: Accords and Preludes have the same clutchs.
Old Apr 2, 2002 | 10:36 AM
Default Re: ACT Clutch (DunReit)
Would a HDSS setup be able to handle a boosted b18b? (to what extent?)
Same question for a stage 2 Clutchnet..
[Modified by Newbie In A Teg, 7:37 PM 4/2/2002]
Old Apr 2, 2002 | 10:41 AM
John's Avatar
New User
HDSS is designed to withstand 286ft-lbs of torque... XTSS 386ft-lbs torque...
Old Apr 2, 2002 | 01:56 PM
LostGsr's Avatar
This might be a stupid question but would higher pedal pressure cause the seal on the clutch cylinder to fail faster?
crazyguy
Jun 21, 2007 08:11 AM
whiskaz
Dec 16, 2006 01:55 PM
StylishDOHC
Jan 1, 2006 11:56 PM
kaptr1d
45
Jan 3, 2005 09:49 AM
a z n t a k
Apr 8, 2002 09:53 PM
