Which Header to use on LS/VTEC...
Old Apr 3, 2002 | 12:17 PM
fastbrakes's Avatar
Default Which Header to use on LS/VTEC...
WIll a header designed for the LS fit the LS/VTEC combo OK or should I get the GSR header?
I plan on only taking the engine to 8K RPM so the shorter length of the GSR header isn't really necessary.
Old Apr 3, 2002 | 12:50 PM
Kataku2K3's Avatar
Default Re: Which Header to use on LS/VTEC... (fastbrakes)
Just get it for an LS, it's a whole bunch easier then having to have an O2 sensor port welded into a GSR header. If you wanna spend a little more i would recommend the JDM ITR header.
[Modified by JDMspecEG6, 9:51 PM 4/3/2002]
Old Apr 3, 2002 | 01:47 PM
sgT's Avatar
sgT
the lengths of theprimaries and secondaries on both headers are the same.
The ls has a longer collector pipe with an o2 bung in it due to differences in the
exhaust and catalyst. What header you get would depend on what car and
exhaust setup you have.
frisbie21789
Feb 7, 2008 03:13 PM
tumbleweed
Feb 6, 2004 10:04 PM
SPOOLINVTEC
Oct 2, 2003 05:54 PM
TurbothisLS
Mar 17, 2002 09:05 PM
