OIL SCHOOL fan problem !!!!
Old Apr 2, 2002 | 07:17 PM
SCsol's Avatar
Default OIL SCHOOL fan problem !!!!
ok putting a LS vtec motor in a 91 interga using a non obd b16 head on a new OBD2 block (low miles) but the rad fan wont come on if the *ECT switch* is not pluged in (back of motor) what else will make the fans come on is there anything eles, other sensors that will control the fans
Old Apr 3, 2002 | 12:53 AM
kinesistech's Avatar
Default Re: OIL SCHOOL fan problem !!!! (lowsol)
Where the lower coolant hose connects to the engine is the thermostat. On the thermostat housing there should be a 2 wire switch. Its the new rad. fan switch. Connect your 2 wires from the back of the engine to it.
Old Apr 3, 2002 | 01:21 PM
SCsol's Avatar
Default Re: OIL SCHOOL fan problem !!!! (kinesistech)
thanks so if i take the two wire from the back (green & black *i think*) and conect them using the sensor in the rad hose housing the ran fan will work fine
all that sensor does is complete a cruict to turn the fan on right no voltage or ohm's right and does not go to the ECU i dont want to fry the ECU
thanks again for all your help
97civicdx
Jul 20, 2010 05:04 AM
drift878
Apr 22, 2008 05:57 PM
hondaon18's
10
Jun 4, 2007 07:45 PM
blaster834
Sep 16, 2004 11:52 AM
