Code 12??????Help
Old Apr 3, 2002 | 05:15 PM
B16edCRX's Avatar
Default Code 12??????Help
I have a 90 CRX with a J-spec B16A swap with AEM CAI, DC Sports 4-2-1 header, Tanabe Racing Medallion CAt-back, ACT clutch, and shaved flywheel. I am throwing Code 12 which is the EGR (exhaust gas recirculation) lift sensor circuit. does anyone know what this does, where it is at, or how to fix it? Thanks for any help you can provide.
Old Apr 3, 2002 | 05:33 PM
B16edCRX's Avatar
Default Re: Code 12??????Help (B16edCRX)
ttt
Old Apr 4, 2002 | 01:11 AM
91 Civic B16's Avatar
are you absolutely sure its a code 12?? i have a b16a1 w/ pr3 ecu. this motor does not have an egr valve. it uses a pcv valve instead for exhaust gas recirculation.
Old Apr 4, 2002 | 02:42 AM
EE_Chris's Avatar
Default Re: Code 12??????Help (91 Civic B16)
Lets clear this up:
EGR = Exhaust Gas Recirculation
PCV = Positive Crankcase Ventilation
The two are NOT the same, nor is there function anything alike.
The PCV does not route exhaust gas...it routes crankcase vapors.
Old Apr 4, 2002 | 08:14 AM
B16edCRX's Avatar
Default Re: Code 12??????Help (EE_Chris)
OK I found out the most of the problem. B16 has no EGR, so therefore it is a wiring problem. I looked in the wrong helm manual when I looked up EGR (yes i am dumb sometimes). Does anyone have any idea of what could be wired wrong to cause this. Thanks
Old Apr 4, 2002 | 12:30 PM
oops sorry bout the misinformation. i confused blow by gas recircultion with exhaust gas recirculation....
doh!!!!!!
ef nine
Jan 27, 2010 09:32 AM
g3teg97
Jul 11, 2006 04:01 PM
Linh.
Dec 10, 2005 10:03 AM
sytema
Jul 6, 2003 09:43 PM
