rebuilding B18C1 motor--what do I need to replace?
Old Apr 3, 2002 | 12:11 PM
hatchy's Avatar
Default rebuilding B18C1 motor--what do I need to replace?
I am doing a total rebuild (block and head), what else do I need to replace besides:
Crankshaft main bearing
connecting rod bearings
head gasket
water pump
oil pan gasket
camshaft seals
rea main oil seal
timing belt
The head has new valves, valve springs (inner and outer), retainers. Keeping stock cams.
Block gets new pistons, rings, rods, wrist pins, stock crank.
I am getting ready to order all the parts for this, so if you can think of anything I may have missed, pls advise!
Thanks
Old Apr 3, 2002 | 12:15 PM
CivicEK.PDX's Avatar
Default Re: rebuilding B18C1 motor--what do I need to replace? (hatchy)
buy the bottom end rebuild kit from Honda (about $40).....bearings...and new headgasket......they also have a rebuild kit for the top end (about $125) too.
Old Apr 3, 2002 | 12:19 PM
hatchy's Avatar
Default Re: rebuilding B18C1 motor--what do I need to replace? (CivicEK.PDX)
What does it include?
Old Apr 5, 2002 | 12:34 PM
hatchy's Avatar
*bump*
I know someone here has rebuilt their motor, I just dont wanna forget a seal or something dumb.. thanks
Old Apr 5, 2002 | 12:46 PM
Sleeper's Avatar
Head bolts
Main bolts
Oil pump
Oil Pan gasket
Valve cover gasket
Old Apr 5, 2002 | 12:53 PM
bruthaboost's Avatar
If boost is ever in your future, go for headstuds instead of bolts, and stainless on the exhaust valves.
Old Apr 5, 2002 | 03:25 PM
hatchy's Avatar
Default Re: rebuilding B18C1 motor--what do I need to replace? (b18bpwr)
Yup.. APR and got SS valves on both intake and exhaust.
Old Apr 5, 2002 | 04:01 PM
rebuild kits for bottomend:
All Orings
All Seals
All Gaskets
same for topend:
All parts for orings, gaskets, etc.
x still jaded x
Sep 7, 2010 05:19 PM
laziebun
Nov 4, 2007 04:57 PM
blackboostcoupe
Jul 26, 2006 05:12 PM
ludesleep
May 12, 2003 10:13 PM
3rdGteg
Sep 27, 2002 05:56 AM
