CRV Head on A LS Block
Old Apr 2, 2002 | 08:43 AM
Hybridhonda10's Avatar
Default CRV Head on A LS Block
Would A B20 Head bolt up to and B18B block, and if its possible it would have alot of displacemnt right. Also would all Parts from a B-series head work on the CRV head.
Old Apr 2, 2002 | 08:48 AM
ekb18c's Avatar
Default Re: CRV Head on A LS Block (Hybridhonda10)
Just one question. Why?
Old Apr 2, 2002 | 08:55 AM
eg6ajk's Avatar
B18B head = B20B/Z head no difference at all, same port size, all the same
bottom end on the other hand is different 84mm vs 81mm for b18b
Old Apr 2, 2002 | 09:23 AM
dohcsideSi's Avatar
Default Re: CRV Head on A LS Block (eg6ajk)
i sold a kid my b20 head for his ls (while he ports and polishes the ls head), but it's kinda of pointless to swap although it does work..........
Old Apr 2, 2002 | 09:36 AM
CopperSol's Avatar
Maybe I read this wrong but are you assuming that changing an LS head to a CRV head will increase your displacement? If you honestly think that, then right now I have a really bad urge to flame you, but maybe your just a newbie so i'll be nice...the cylinder head from the b20 is identical to the b18b1, the b20 is even given a shittier intake manifold...the only reason it puts out the horsepower that it has is from the 2.0L of displacement. Dont waste your time and just put a VTEC head on that LS block.
Old Apr 2, 2002 | 10:02 AM
Default Re: CRV Head on A LS Block (CopperSol)
Thaks for help ya'll I was unaware a B20 Head was the smae as a B18B head. I am not too familiar with that particular honda engine. Thanks for clearing that up. But one other question do they make forged B20 pistons or could I use Forged ITR pistons
Old Apr 2, 2002 | 10:11 AM
Spade's Avatar
B20 Bore size is 84mm
B18 Bore size is 81mm
If you plan on B20 pistons.......sigh, there is a lot behind this......do a search for Compression ratio and find boganglez (sp?) CR calculator.
Old Apr 2, 2002 | 08:19 PM
StorminMatt's Avatar
Actually, the B20 head and B18B head have different part numbers. My 1995 B18B has a PR4 head. But my 2000 B20Z has a P75 head. I am not sure what the exact differences are.
Old Apr 3, 2002 | 01:20 PM
CopperSol's Avatar
Default Re: CRV Head on A LS Block (StorminMatt)
the USDM b20 that we typically see around here is the b20b....this uses the same head as the b18b...if you got a b20z from japan then it might have a different head on it cause the JDM b20 does have a bit more power
Old Apr 3, 2002 | 01:23 PM
The_Head's Avatar
They probably had different part numbers because one was for an OBD 1 motor and the other was for an OBD 2 motor.
Old Apr 3, 2002 | 01:31 PM
Kataku2K3's Avatar
Default Re: CRV Head on A LS Block (xThexHeadx)
Think it's time for some CRVTEC!!!!
DAfireman
Nov 25, 2004 10:17 AM
Nebula
Nov 25, 2002 05:39 PM
LSBeast
10
Sep 17, 2002 06:44 PM
dfoxengr
Aug 10, 2002 08:22 AM
Chuji
Sep 6, 2001 05:25 PM
