camber adjustment products
Old Apr 1, 2002 | 07:07 PM
01 ITR 757's Avatar
Default camber adjustment products
Just finished installing Tein RA`s on my 2001 ITR and also installed Ingalls # 3892 rear camber adjusting kit which worked ok. When I tried installing the front Ingalls # 3573 kits I could only get +1 degrees positive camber. I removed the Ingalls front kit and reinstalled the stock `A` frame mount and ended up with 1/2 degree negative camber. I want to run 2 degrees negative camber on the front end and 1 1/2 degrees negative camber at the back. Does any manufacturer make something that will do this. I have only lowered the car about 1 1/2 inches since it is my daily driver. I have searched Honda-tech but can`t find anything.
Old Apr 1, 2002 | 07:15 PM
SCsol's Avatar
Default Re: camber adjustment products (01 ITR 757)
try going with skunk2 front camber kits people have said there realy good camber kits
Joon Joon
Suspension & Brakes
13
Feb 13, 2012 08:25 PM
mattdenali
Suspension & Brakes
May 26, 2005 09:21 PM
pcorad
Dec 1, 2002 08:09 PM
pcorad
Dec 1, 2002 06:18 PM
mr tl
Sep 7, 2002 09:39 AM
