Help removing crank
Old Apr 6, 2002 | 06:02 PM
Prelude Vtec 23's Avatar
Default Help removing crank
Im getting ready to ship out my block to golden eagle to have it resleeved. Everything on the block has been removed the pistons, rods ect. But I am having trouble pulling out the crank. The crank is ready to be pulled out, except that the gear on the end is still on. I need to take this gear off so I can lift up the crank, the gear I am talking about has that little "key" on it ont the end of the crank. I looked through my Helms and it doesnt say how to remove it. Since it has the "key" I figure I just pull it out like my cam gears but it seems stuck. I've tried to pry it out but it wont budge. Does anyone have any suggestions on how I can pull it out?
Old Apr 6, 2002 | 08:52 PM
CivicEK.PDX's Avatar
Default Re: Help removing crank (Prelude Vtec 23)
knock around with a hammer to try and FULLY straighten it.
Old Apr 6, 2002 | 09:01 PM
poison's Avatar
use a hammer and try getting it out, u have all bearings and everything else cleared right?
Old Apr 6, 2002 | 09:09 PM
Default Re: Help removing crank (poison)
Yeah everything is out, but what do I hammer? I tried to pry it out but it just wont budge. I even tried to pull out the "key".
Old Apr 6, 2002 | 09:23 PM
poison's Avatar
ummm, then only thing that i would suggest is getting a wheel puller (most commonly used as "steering wheel" claws) they have different sizes for that, check 'em out and see what one best fits
sounds like u might just have to get a key that fits it, or find something that will turn it w/o turning the whole thing. btw, the bolt in there is backwards to a regular bolt so it would turn counter-clockwise to get it off
Old Apr 7, 2002 | 01:47 AM
Thanks alot i'll try that, someone also suggest I get a "gear puller" cuz sometimes the gears get stuck pretty good that prob the same thing you mentioned I use. The little things are always the hardest!!
Old Apr 7, 2002 | 11:58 AM
poison's Avatar
ya, gear puller, wheel claw..all the same thing, just have different sizes
good luck man
Old Apr 16, 2002 | 09:50 PM
B18C1 for fun's Avatar
Hey man, all you need to do is rent a Ford F350 Dooley and buy a chain. Chain the motor on a tree and chain the crank pulley to the Dooley. Put that thing in drive and your done. heheheheh, like hybrid dream said. "Don't you know anything noob?
Old Apr 16, 2002 | 09:57 PM
Default Re: Help removing crank (gsrpwr704)
Yeah sorry didnt try that...got out already anyways, this post kinda old maybe you could look at the date next time.
Ransom
Jun 4, 2023 06:03 AM
Hondacamaro
Mar 20, 2015 10:21 AM
Ransom
Feb 15, 2006 11:09 AM
Sam1am26
Mar 22, 2004 05:24 PM
ludesleep
Mar 17, 2003 03:29 PM
