B16A SIR 1 long block in 90 civic dx?
would that engine fit in my 1990 Civic DX sedan? if so would it be an easy swap?
any help is appreciated.
thanks in advance.
thanks in advance.
Re: B16A SIR 1 long block in 90 civic dx? (northernvermonter)
Yup it will work and it's a fairly straight forward swap. What do you mean by "long block"? You're not trying to use your DX tranny on the B16 rite? cuz that's won't work. You will need the basic motor, tranny, axles (hybrid ones can be made), ECU (prefferably PR3) and mounts (look into HaSports), and linkage (HCP and HaSport both make that too).
should work nicely, the only hard part is modifying the wirng harness to accept the pr3 ecu, or you can just buy one from hasport for like 300, ohter then the wirng issues. the swap is straight forward.
trampuscool
12-20-2010 08:16 AM
Civiclized
02-02-2006 10:23 AM
Sean_b
04-06-2004 12:50 PM
