is it a basic bolt on if i...............
Old Apr 4, 2002 | 09:03 PM
hobo79's Avatar
New User
Default is it a basic bolt on if i...............
is it a basic bolt on if i get the front and rear rotors, brake discs, etc from a 99-00 civic SI into a 98 civic ex coupe?......wanna change the rear drum brakes to disc brakes.
Old Apr 5, 2002 | 02:46 AM
hobo79's Avatar
New User
Default Re: is it a basic bolt on if i............... (hobo79)
does anyone know or should i just get the AEM brake kit?
Old Apr 5, 2002 | 06:42 AM
bigblockEG's Avatar
You should also get the Master Cylinder and the Prop. valve from the SI or a four wheel disc integra. For the back you are going to need more than just an AEM kit. You need the hub and complete disc set-up before you upgrade. If you want to upgrade the fronts with AEM and add SI rears that would work nice. The difference is only .5 inches i believe between the front SI's and EX's. From 9.5 to 10" rotors. The only thing is that its nice to have a uniform list of parts so that incase you need to add something later you dont have to remember all of the donor parts that you got. $0.02
Old Apr 5, 2002 | 08:37 PM
hobo79's Avatar
New User
Default Re: is it a basic bolt on if i............... (bigblockEG)
oh yeah, forgot about that part......in case one day i am too lazy to change my brake pads, etc. and they put the wrong ones on cuz its the AEM big brake kit, etc. THANKS for the note!
Cap'N Chronic
Mar 27, 2022 07:16 AM
05Bodyssey
Sep 5, 2017 12:42 PM
harwood39
Aug 2, 2004 09:08 AM
tlclee
Sep 20, 2003 10:03 AM
DOHCTOR
May 17, 2003 10:21 PM
