leaking coolant... can't find source
My buddy's '94 GSR jsut started leaking coolant... and its definitely not one of the hoses. I can't find the exact source, but it looks like its coming out of the top of the radiator itself.... not the cap... has anyone actually had a radiator itself break and start leaking? Any thoughts?
yeah the plastic end tanks on radiators can crack and leak, especially under thermal expansion. if you feel its necessary to locate the spot..., they make an ultraviolet dye that you mix with the coolant...you can detect the leak with a blacklight.
i used to have this prob of coolant slowly steaming out of the top of my aluminum radiator, just replace the cap (u might wanna get one with higher PSI -- wouldn't hurt), also get some radiator sealant that u put in ur coolant (looks like dirt, but is more liquidated), put that in there, run it for about a month, then completely flush it out and put clean coolant in there. should fix 'er
ShadowDaisy82
11
Aug 7, 2015 10:34 PM
crxaddikt
Mar 25, 2014 11:00 PM
