Problems with LS fuel pump with an ITR motor?
Old Apr 1, 2002 | 08:49 PM
NWPNOMORE's Avatar
Banned
Default Problems with LS fuel pump with an ITR motor?
I swapped an itr motor into my ls integra. Everything seems to run good, but I'm having a slight problem. My idle is inconsistent and it jumps around a tad. I'm trying to figure out the reason why I getting code 91, which has to do with the fuel supply. Fuel Tank Pressure Sensor - low input. Anyone have any ideas of other things i can check for? Thanks.
[Modified by NWP4LIFE, 5:58 AM 4/2/2002]
Old Apr 1, 2002 | 09:21 PM
salbaje's Avatar
Default Re: Problems with LS fuel pump with an ITR motor? (NWP4LIFE)
you are probably not getting enough fuel in the motor. try changing to a gsr or itr fuel pump or buy an adjustable fpr
slowpokecivic
Nov 9, 2005 09:46 PM
cliff666
Jan 7, 2004 07:40 AM
hsilva
Sep 3, 2002 04:21 PM
Project X
Dec 9, 2001 10:01 PM
SpoonFed
Nov 3, 2001 06:33 AM
