Knocking on startup
Old Apr 6, 2002 | 08:50 PM
CivicEK.PDX's Avatar
Default Knocking on startup
Always when I start my car up for the first time or when its had enough time to cool down (like 30 mins in 50 degree weather) I get a kn0ocking noise for like 2 seconds then no more. The car then runs SMOOTH. Any ideas.
ASlso this is an EK with a B16A2 with ITR valves and valvetrain, ITR IM, and 11.3:1 CR. Also timing is set at about 18. Also I think it makes that noise at 16.
Old Apr 6, 2002 | 08:57 PM
poison's Avatar
Default Re: Knocking on startup (CivicEK.PDX)
hey, any symptoms of where the knocking noise might be coming from?
is it near starter.......tranny, inside the engine?
details details
Old Apr 6, 2002 | 11:02 PM
tinkerbell's Avatar
Default Re: Knocking on startup (poison)
mine makes that noise too,
stock B16A with K&N pod filter.
i think it sounds like a'knock' ie pre-detonation.
not sure why, but cause it only happens at start-up, i never really thought much of it...
t..
Old Apr 7, 2002 | 03:29 AM
Default Re: Knocking on startup (tinkerbell)
its sound from the driver side.....near the timing belt area. My belt looks STRAIGHT on the alt. Also I noticed that the belt (with the cam gear cover off) has a slight flexing (as in the belt sways/waves) of about 1/5 a cm. Is this normal....or should I maybe try and tighten it up. Hmmmmm.........
Old Apr 7, 2002 | 06:10 AM
rainforest's Avatar
if its a hard metal sound there is a 100% chance it is a main bearing. when you first start your car you have no oil pressure. when there is no lubrication you can hear your knocking thats a rob bearing.
Old Apr 7, 2002 | 01:15 PM
Default Re: Knocking on startup (rainforest)
I just replaced the bearings. Its like if you tap on wood lightly.......Ill check the bearing when i put in my new motor.
Old Apr 7, 2002 | 05:01 PM
shamoo's Avatar
Will you make something up for me please?
What kind of pistons are they? With my experience JE's make lots of noise on a cold startup....almost like detonation, but it's piston slap.
Old Apr 7, 2002 | 05:41 PM
Default Re: Knocking on startup (shamoo)
they are the stock PR3's......
96Hatchy0
Feb 15, 2011 10:34 AM
ixsan25
Apr 12, 2008 06:43 PM
zxracer3
Jul 1, 2007 01:20 PM
VTEC-LUDE
Jun 1, 2006 05:14 AM
CivicEK.PDX
Apr 7, 2002 06:17 AM
