DIY Wideband O2 & Lambda meter
Old Apr 3, 2002 | 09:33 AM
qtiger's Avatar
Default DIY Wideband O2 & Lambda meter
Check this out, its a DIY kit for a wideband O2 that can read in A/F or lambda.
They also just started selling fully assembled kits. Fully assembled, it looks like about $300 including O2 sensor. Way the hell cheaper than many others on the market. *cough* Motec *cough* From what I've gathered its reasonably accurate as well.
For those of you with the electrical knowledge (And about 10 hours of spare time on your hands) its closer to $220 if you build it yourself.
The O2 sensor they use is from a 92-95 Civic, so many of you may have it floating around your spare parts bins. MrFatBooty and myself believe it to be the O2 sensor from a VX hatch, which would explain its accuracy. Part number is 36531-P07-003 in case anyone cares.
The web site is rather technical. Be warned.
http://www.techedge.com.au/vehicle/wbo2/default.htm
[Modified by qtiger, 1:34 PM 4/3/2002]
Old Apr 3, 2002 | 09:45 AM
Austin's Avatar
Default Re: DIY Wideband O2 & Lambda meter (qtiger)
Yep...my board just showed up on Monday...looks like I'll have it done....? and it shouldn't take 10 hours to solder everything up. It is the O2 sensor for the VX and the HX cars.
Austin
Old Apr 9, 2002 | 07:14 AM
-TJ's Avatar
-TJ
Default Re: DIY Wideband O2 & Lambda meter (Austin)
Please let me know when you get your's built. A friend and I went in on one - he, being the more electronics saavy, built it. However, it appears that we have a problem with it. The display reads 14.5:1 no matter what - free in the air, in the car, hot, cold, etc...
It would be nice to know if your's works, or if you have the same issue.
THanks,
-TJ
Old Apr 9, 2002 | 07:45 AM
mantic6t9's Avatar
Default Re: DIY Wideband O2 & Lambda meter (-TJ)
That's pretty cool, you guys let us know if it "works", hope you don't have the same problem as TJ.
Travis
[Modified by mantic6t9, 4:46 PM 4/9/2002]
Old Apr 9, 2002 | 08:36 AM
Austin's Avatar
Default Re: DIY Wideband O2 & Lambda meter (mantic6t9)
I haven't aquired a O2 sensor just yet...so I haven't been able to test it, go to the website and read through all of their troubleshooting, you might just find something. Also pull out a magnifying glass and look at all of your solder joints, you could have a bridge in there somewhere.
Austin
Old Apr 9, 2002 | 10:00 AM
-TJ's Avatar
-TJ
He just called me and reported that he has narrowed it down to the board. The 02 voltage fluxuates, but the output to the display does not....he's e-mailing Peter. He's also 99% sure it's not a solder bridge. I vote bassackwards component or a bad component.
Thanks,
-TJ
Old Apr 9, 2002 | 11:54 AM
Ubermensch's Avatar
Do a search on http://www.supraforums.com and I'm sure you'll find some good info on DIY kits.
Old Apr 9, 2002 | 12:04 PM
sackdz's Avatar
Wut makes this so accurate? And it only displays instantaneous, a/f rite?
Is the civic vx/hx O2 super-special?
Old Apr 9, 2002 | 12:16 PM
-TJ's Avatar
-TJ
Default Re: DIY Wideband O2 & Lambda meter (sackdz)
read all about it here:
and:
http://www.diy-efi.org/diy_efi/projects/diy_wb/
The techedge kit's instantaneos A/F display is loggable to a PC.
Old Apr 9, 2002 | 12:21 PM
Spade's Avatar
So you are saying that the HX and the VX both already come with Wideband O2's!?!?!?!
Old Apr 9, 2002 | 12:34 PM
-TJ's Avatar
-TJ
Default Re: DIY Wideband O2 & Lambda meter (Spade)
Read, read, read....from the diy-wb site:
"A typical OEM switching type O2 sensor will not work with this project. This
project requires a 2 cell wide band O2 sensor that was used on a lean burn
Honda Civic. It is available from Honda dealers, and from http://www.hparts.com.
Application/part number:
92-95
Honda Civic
1.5 VTEC
36531-P07-003
The generic NAPA equivalent may be cheaper, but may not be widely available:
Part number OS791"
aojtin
Jul 9, 2008 01:40 PM
King V
Nov 30, 2007 04:40 AM
s2k drifter
Mar 30, 2005 01:11 PM
speed
Nov 19, 2002 04:28 PM
REDBARON
Nov 2, 2002 01:22 PM
