Bearing selection help @!!
Old Jun 5, 2003 | 05:03 PM
senpai's Avatar
Default Bearing selection help @!!
Ok, my main bearings are all within spec. However, the rods are way off. Knowing that the ACL bearings are GREEN color code, which OEM bearings should I get to tighten up my clearance. (I had like .002-.003" of rod bearing-journal clearance.)
Do I get BROWN or YELLOW?
Old Jun 5, 2003 | 05:09 PM
dfoxengr's Avatar
Default Re: Bearing selection help @!! (maztur)
just get aftermarket ones, theres no matching with them
Old Jun 5, 2003 | 05:19 PM
senpai's Avatar
Default Re: Bearing selection help @!! (hybridvteceg)
I have ACL, the clearances are too large. I need to tighten up the clearances.
Old Jun 5, 2003 | 06:06 PM
dfoxengr's Avatar
oh. hmm.. dk
Old Jun 6, 2003 | 07:49 AM
senpai's Avatar
Old Jun 6, 2003 | 09:51 AM
msilbernagel's Avatar
Sounds like you're past the service limit for the crank journals. The OEM bearings appear to come in about 0.0001" steps. You could turn the crank and step up to .010 under bearings -- doable with aftermarket parts like ACL... or, you could just max the OEM ones and try to get close.
Check out this thread: https://honda-tech.com/zerothread?id=474555
Here's the data:
Conrod Bearing Set:
1.510-1.507mm 0.0594"-0.0593" -BLUE
1.507-1.504mm 0.0593"-0.0592" -BLACK
1.504-1.501mm 0.0592"-0.0591" -BROWN
1.501-1.498mm 0.0591"-0.0590" -GREEN
1.498-1.495mm 0.0590"-0.0589" -YELLOW
1.495-1.492mm 0.0589"-0.0587" -PINK
1.492-1.489mm 0.0587"-0.0586" -RED
Rod Bearing Part Numbers:
13217-PR4-A02 RED
13216-PR4-A02 PINK
13215-PR4-A02 YELLOW
13214-PR4-A02 GREEN
13213-PR4-A02 BROWN
13212-PR4-A02 BLACK
13211-PR4-A02 BLUE
Mark
jtracing919
Feb 12, 2006 04:25 PM
totalimpact
Nov 11, 2003 06:39 PM
senpai
Jun 5, 2003 01:29 PM
