how do you clean the fuel system?
Old Jun 8, 2003 | 09:56 AM
Mikey3000's Avatar
Default how do you clean the fuel system?
at gas stations they say they can clean your injectors and intake valves and all that. i've had it done before but they charge way too much. how do they do it? take a bottle of injector cleaner, plug it up to the brake booster.....something like that. someone hook me up with the step-by-step procedure. my car really needs it. thanks.
Old Jun 9, 2003 | 04:41 AM
Mikey3000's Avatar
Default Re: how do you clean the fuel system? (Salvatore Leone)
i know someone in here has worked at a Jiffy Lube or a Mobil before.
Old Jun 9, 2003 | 05:48 AM
3gdude's Avatar
My shop uses an injection cleaning machine that we put GM fuel injector cleaner in. You attach it to the pressure test port on top of the filter. Then you have to block the return line going to the tank and also disable the fuel pump. Now you can start and run car off the pressure coming from machine (40psi). On my personal car, I would remove oxygen sensor and put an old one in the hole until cleaner has finished burning..If you dont attach to the fuel system the injectors wont be cleaned...3gdude
movingIIshadow
30
Feb 29, 2020 07:36 AM
Gennady
Nov 1, 2013 10:18 AM
lude98SH
Nov 13, 2005 08:02 PM
infamousALLMTR
Mar 2, 2004 04:46 PM
koticimage
Oct 3, 2002 02:01 PM
