o2 sensor
Old Jun 5, 2003 | 09:35 PM
bOOsTiNSoHcVtEc's Avatar
Default o2 sensor
well i did a swap and i had to extend my o2 sensor wires to reach the 02 sensor plug. After i did all that and hooked it up the plug i still have a engine check light...i then checked the ecu codes and it said that i had a code 1 and code 41, which are both oxygen sensor codes. What could i be doing wrong?
Old Jun 5, 2003 | 11:28 PM
mmuller's Avatar
Mad Scientist
Default Re: o2 sensor (bOOsTiNSoHcVtEc)
i think the o2 sensor wires need to be shielded to work properly
Old Jun 6, 2003 | 04:22 AM
monicle's Avatar
What is the swap that you did? I just put a b18c into a 2k hx and my wiring harness conversion harness wasnt wired correctly in a couple places. After i corrected it it worked fine. I didnt use shielded wires either. but I was only throwing code 41.
Old Jun 6, 2003 | 07:48 AM
Default Re: o2 sensor (monicle)
its a b18b into a 95 ex...how do i make them shielded?
Old Jun 6, 2003 | 08:32 AM
Blaze45's Avatar
Brrraaaap!
Since you have two 02 wires, I have herd of people hooking em up to the wrong. They switch em and then they throw the 41 and 1 codes, cause there were interchagned. Just a suggestion.
Blaze
Old Jun 6, 2003 | 09:30 PM
Default Re: o2 sensor (Blaze45)
its obd 1...so theres only 1 o2 sensor...thanks for the suggestion tho
JasinC19
Oct 11, 2007 09:47 AM
oh_lee_allen
Apr 29, 2007 01:25 PM
bmiller17
Jan 20, 2006 08:11 PM
pr_tony_montana
14
May 21, 2005 01:25 PM
Jasno161
Mar 1, 2005 04:31 AM
