Taking Tranny Case Off. Snap ring?
Old Jun 4, 2003 | 06:45 PM
nsxmatt's Avatar
Default Taking Tranny Case Off. Snap ring?
I'm trying to seperate my tranny case to change the input shaft bearing and I can't find the snap ring to get the case apart. It comes off about 1/4 inch then stops. Anyone have a pic or decent summary on how to find and remove it?
Old Jun 4, 2003 | 07:24 PM
jlicrx's Avatar
Default Re: Taking Tranny Case Off. Snap ring? (nsxmatt)
on the back of the case (the part you are trying to take off) you will see a big plug with a square hole in it that your 3/8" drive ratchet will fit in - remove the plug and you will see the snap ring below it - use a set of needle nose pliers and spread the snap ring as far as you can and pull the case off
Old Jun 4, 2003 | 07:26 PM
nsxmatt's Avatar
Cool! I'll finish venting myself on the shoplight and try that in the morning Thanks for the help!
Generic User Name
11
Jan 8, 2005 01:46 PM
crexer
Oct 4, 2004 06:00 PM
Tyson
Apr 22, 2004 06:20 PM
jolt-tsp
Jun 5, 2003 07:00 AM
S13 slide
Apr 11, 2002 10:54 AM
