CEL Misfire
Old Jun 4, 2003 | 06:00 PM
DC2Slow's Avatar
Default CEL Misfire
00+ GSR for mods click on link found in sig
I tried search didnt find any real answers your theories are very welcomed
Symptoms:
no power loss CEL is on i forgot the number of the code but it is the one for misfire.
I was running rich because one of my Injectors was stuck open. Also my mechanic accidentally put in LS plugs and i didnt find out till now. Now im running on stock NGK plugs for the GSR. Some people think my o2 sensor could be toasted since of running rich for so long. Thanks for the help.
Old Jun 4, 2003 | 06:05 PM
Turbogixxer's Avatar
Default Re: CEL Misfire (DC2Slow)
it sounds like that injector is fouling your plug on tha one cylinder. While you know that you have to replace that one injector, so go from there and i would change the spark for that cylinder with the bad injector.
Hope that helps!
Old Jun 4, 2003 | 06:58 PM
DC2Slow's Avatar
Default Re: CEL Misfire (turbogixxer)
thanks..yeah i replaced that injector still getting the code.
Old Jun 4, 2003 | 07:15 PM
DC2Slow's Avatar
bump
Old Jun 17, 2003 | 01:15 PM
DC2Slow's Avatar
replaced my spark plugs with BKR7E n NGK blue wires reset the ecu n the code still came back help anyone?
Old Jun 17, 2003 | 02:29 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2Slow &raquo;</TD></TR><TR><TD CLASS="quote">reset the ecu n the code still came back </TD></TR></TABLE>
What code? Did you check the plug wires, cap, and rotor? Did you do a compression test? Are the valves adjusted to tight?
Old Jun 18, 2003 | 09:22 AM
DC2Slow's Avatar
Default Re: CEL Misfire (Chiovnidca)
I already changed the plugs and wires...as for the cap and rotor I only did a visual inspection I didnt find anything wrong with them. Compression test came back good will check on the valves. I will also check which code it is but im pretty sure it was the misfire code. brb
Old Jun 20, 2003 | 09:53 AM
DC2Slow's Avatar
My timming is set at stock 16 +/- 2 the CEL codes are 71-72-73-74 I guess its miss firing in all 4 cylinders...my theories are bad coil or ignitor or something is wrong with my tuning I have a AFC but everything is set to stock. pls help thanks
Old Jun 24, 2003 | 01:44 PM
DC2Slow's Avatar
bump
Old Jun 26, 2003 | 12:29 PM
DC2Slow's Avatar
well this is what i came up with...check ignitor/coil..check ecu..check conncection to VAFC.
Old Jun 30, 2003 | 11:49 AM
DC2Slow's Avatar
disconnected AFC and reset ECU CEL still came back...next step either swap ignitor/coils or ECU.
v-tec maz
Apr 17, 2006 05:02 AM
MOVE OVER
Oct 4, 2005 04:31 PM
AutoboTxEK
Apr 3, 2002 09:49 AM
Babybluegsr92
Jan 24, 2002 05:31 AM
sagaprelude
Sep 6, 2001 08:55 AM
