Blown Head Gasket Diagnosis
Old Jun 5, 2003 | 11:52 AM
Mada's Avatar
Default Blown Head Gasket Diagnosis
Hello everyone, I'm new to the forum and I have a question about a diagnosis I got from the Honda Dealership. I took my 91 Civic in to have the fuel system pressurized b/c it has been smelling like fuel for a while now. They told me I needed a new tank and lines and that I had a major head gasket leak. I asked them how they determined that the head gasket was leaking and they said that when the took the rad cap off, fluid shot out. They said that this was a sign of back pressure in the coolent system because of a head gasket leak. I haven't noticed any power loss or oil in the coolent or vise versa.
I guess I'm asking if this is an accurate way to determine a head gasket leak, or if it's nothing to worry about?
Thanks in advance,
Adam
Old Jun 5, 2003 | 12:21 PM
ykracing's Avatar
Default Re: Blown Head Gasket Diagnosis (Mada)
I wouldnt call that the BEST way to determine if you have a bad headgasket... but a blown HG will sometimes blow thru to the coolant system... (fairly often on a d-series)
Have you ever done a HG on your motor? because it probably needs one regardless of what they told you. There is a replacement gasket that you are supposed to use on those d-series motors... the stock one is a composite metal, and the suggested replacement is a layered metal...
you should just plan to do the gasket regardless... thats my advice. take it for what its worth.
Old Jun 5, 2003 | 12:24 PM
Mada's Avatar
I haven't done one since I got the car two years ago. Is is safe to still drive the car?
Old Jun 5, 2003 | 02:00 PM
ykracing's Avatar
Default Re: (Mada)
as long as you arent losing oil or coolant, you should be fine driving it until you can get it into the shop...
jdmitrdc2
Apr 15, 2009 11:31 AM
da_33
Jan 11, 2007 11:12 AM
sleepyIntegra
May 24, 2004 11:14 AM
redcivic
Apr 22, 2003 03:54 PM
wessieball
Apr 22, 2002 12:51 PM
